streamophile
- Joined
- Oct 7, 2023
- Messages
- 31
- Likes
- 15
Hello ASR,
First-time posting here, I hope you're all doing great.
I'm quite new to the audio world and a couple of years ago I bough a second hand Linn system on the cheap. Linn was the only brand I knew, had heard equipment from and so had some experience with. My father had a full Linn system, so I just followed his steps. That being said, after some reading, I believe I could do better. Therefore, I'm now on a quest to level up my audio setup, and I could really use your thoughts and suggestions to find the best bang-for-my-buck way to do so.
Current Setup:
I'm open to any recommendations or advice you've got as I mainly need help with diagnosing where the main problem is. Feel free to also recommend specific components.
Thanks for your help!
Current Setup:
- Speakers: Linn Ninka
- Amp: Linn Majik (old-school first-gen)
- Source: Chromecast Audio (plugged in via RCA straight into the Majik amp) playing local audio files and Sportify.
- Room reality check: My Linn Ninka speakers are probably too big for my room (20 m2), and I could use something less weighty and space-hogging.
- Amp's age: The Linn Majik amp is showing its age, being a first-generation model and all. Probably it is also close to being underpowered to drive the Ninkas.
- DAC issues: Chromecast Audio's built-in DAC is passable but I think I could do better. I also use the system to watch TV and a separate DAC could allow me to connect the TV digitally rather than through the current RCA connection that is using the TVs probably very poor DAC
- Sound quirks: Sometimes high-pitched frequencies get a bit fatiguing, making me hit the volume down button. Also, I'm missing some bass oomph for my taste, although this mostly happens with not-so-great quality Spotify streaming, which may well be the culprit
- Speaker Swap: Downsizing to sleeker, more modern speakers might help with the room issue. However, I think my Linn Ninkas are the best part of the system (might be wrong).
- Amp Upgrade: I'm also thinking of leveling up the amp which could help balance out those trebles.
- External DAC: Adding an external DAC to my Chromecast Audio, or maybe swapping it out for a different streamer, could be a good improvement. Also, it could be the most wallet-friendly fix if the Chromecast Audio is the culprit.
- Lossless Music Source: Jumping onto Tidal or Qobuz might make a big difference, audio-wise. But it does come with a monthly tab, which I am not very fond off as I do not feel I get my monthly money's worth.
