TL reduces to lumped in the limit of line length/wavelength -> 0. Which is absolutely valid at audio. I can use relativity to describe a pitched baseball, but that would be silly- Newton does it just as accurately.
Look at the pictureIT IS NOT DC. Transient. Do I have to get a definition? .... it is an instantaneous change from 0 to some value that is not 0.
The acknowledged expert in the field drew a simplified circuit and named his book Electrical TRANSIENTS in Power Systems. The author is not the issue. The person reading who does not comprehend the difference between a step function and something that is not a step function is the issue.
Audio is not all transient as your quoted book defines transient. In fact, if we look at digital audio or practical analog audio, anything approaching what most EEs would consider a transient literally cannot exist. Everything is constrained to limited rates of changes which changes the effective characteristic of the wavefront in the cable.
Real speakers are resistive and reactive loads. Real speakers have coil resistance, cross-over resistance, etc. and they are substantial. Whatever model you used for a speaker, just like your model for the cable, is wrong at 100Hz and 1KHz. If you are so sure you are right, then show your work and let the other EEs validate it.
Music is MORE transient in nature than a power transient
A fault may be 10-20 x SS
Transient 2-3 x that
Subtransient 1.5 x
Music?
25-30 dB or more, 20-30x
A power line fault?The size of the fault is meaningless. How fast it transitions from the low state to the high state is.
Look at the picture
The source is DC
Word salad
Transient, by an EE
MUSIC
It is not the dominant as it relates to speaker L sand amp C.Exactly, so calculating an impedance ignoring the dominant lumped value (Resistance) at 100Hz and 1KHz is flawed as is calculating a reflection using a high frequency asymptotic formula for Zo.
A power line fault?
1/4 x 1/60 = 4 mSec
A 1000 Hz note, 0.3 mS
So now it's DC, lolThe source may be "DC", but the switch causes an instantaneous voltage change on one end of the cable from 0 to the DC level ..... instantly. That is quite difference from being connected to say an AC generator and the switch closing at the zero crossing ... i.e. audio.
We do not care about energy converted to work.
What is 'near instantaneous'Huh? 4msec? Mechanical switch closure. The transient is a near instantaneous transition unless the voltages are perfectly matched or the switching happens at a zero crossing.
IncorrectYou calculated a Zo for the cable, however, as SIY noted, at audio frequencies, you can just use a bulk model. However, you ignored the dominant bulk element in a cable at audio frequencies, resistance. Your Zo below, 26.3 ohms is wrong and meaningless for an analog audio application.
So now it's DC, lol
You said it wasn't instantaneous before?
Quote
looks like an non-ideal transmission line where the input is not a rapid change but frequency constrained voltage change?
LolSo now it's DC, lol
Quote
What is instantaneous?The UNCONNECTED voltage source is some high voltage, lets call it 10,000. One side of the unconnected transmission line is 0 as is the other before the switch closes (parasitics -- I will take license). When you close the switch, that side that is not grounded goes from 0 to 10,000 instantly. There is no situation in analog audio that remotely operates like that.
Incorrect
It has nothing to do with transient response.
The 28.3 is applicable for this analysis
I get it. You have no idea what characteristic impedance is, what Zo is (at all frequencies), or the difference between what a step function is, and well, not a step function.
The 26.3 is ONLY applicable if there is a step function (or close to it). It would be important if you were using the cable say for SPDIF. For analog audio, no.
No, it applies to ANY reactive power waveform regardless of frequency (within the audio domain)
