Bamyasi
- Joined
- Feb 19, 2019
- Messages
- 487
- Likes
- 354
I've been using Fire TV Stick 4K (2018) with the latest firmware updates and I can assure you it does work, including 24/192 via optical to the DAC, provided that you use the right HDMI extractor. The latter can be tricky to find since few modes advertise this capability, and those which do often does not work. I have posted my experience with various HDMI extractors several times on other threads, check this thread, for instance.The Fire Cube and the latest Fire TV stick will output 192/24 over HDMI.
I’d be interested to see this tested.
Another tricky part with HDMI extractors is that people with AVR usually have their Fire TV Stick inserted directly in the AVR's HDMI port and extractor into HDMI output. This often won't work because many AVRs do not support high rate PCM audio and would prevent HDMI extractor from outputting it during EDID negotiations. I do not have an AVR and my FireStick is plugged into extractor directly, this way you can use DIP switches on the extractor to force high rate PCM pass-through from HDMI input to its S/PDIF output (coax or optical).
