Bass direction is audible
Well I need to add more detail to this. I was referring to the part about us having super powers to hear direction of bass in rooms. According to the research I've read from Toole and Geddes, rooms make that impossible below around 80 Hz. So it's possible for the upper bass area, but our resolution or ability to pinpoint the direction doesn't get good until closer to 200 Hz.
You may also want to read Griesinger, who is a big believer in the effect of stereo subwoofers. The subs need to be set up a certain way, on either side of the listener. My subs are pushed to the corners of the room and crossed over at 50Hz. I tried that experiment mentioned earlier in this thread where I played a test tone on one sub and I could easily hear its direction, but I did not do it blind and I did not measure for distortion.
Griesinger talks about an envelopment effect with bass when it is set up a certain way. @Matthew J Poes tested this and didn't think the juice was worth the squeeze because of 1) how small the effect was, 2) how little content could take advantage of it, and 3) that setting up your system in such a way precludes summing bass sources for modal smoothing.
It’s research not gospel. Research, particularly limited research will from time to time be augmented or even superseded by newer better research
@Thomas Lund calls this ability "super power" and he states that we don't loose it when being in a room.
I never-ever experienced right proportions with subs far and crossed high (more than 60Hz) and I suspect localization is one of the causes.
This is a particularly interesting thread. Thank you for the link.
My take on reading through it is that there is general agreement spatial cues are possible from stereo bass below 80Hz in real rooms, but that room modes will destroy the effect. Poes’ point wasn’t that the effects don’t exist, but rather that for the type of music he enjoys listening to, bass in summed to mono and the effect is therefore not available. And that for those tracks where he has experienced the effect, it was small and easily lost, so overall for him not worth the effort. Further, he asserts that this is will be true for most listeners/consumers, so for most folks simply not worth the bother. I think this is also the viewpoint the Harman solutions are based on. One could argue that a smooth in-room FR is the single most important factor of sound quality, so to the extent that room modes are more effectively compensated for by using multiple subs summed to mono, for many listeners that is going to be the preferred solution.
Now, there are experts who say there are significant benefits to preserving spatial cues in the bass region when such exist in the recording. If I read correctly, j_j and Thomas Lund are two such experts. What I get from them is that the bass needs to come from multiple sources, positioned in the front and back of the room, perhaps also on the left and right sides, and the room modes have to be controlled. So there’s the rub. Acoustic controls, i.e. bass traps, to do this effectively aren’t ever going to happen in my home. One could have each individual channel play down to 40Hz, sum the rest to mono and then employ bass management or DBA below 40Hz, but that wouldn’t address room modes above 40Hz. So what’s the answer? Is it the @KSTR method described in post #29 of this thread? I think that would get you only two channels of bass, L&R, whereas to get the full-on benefit j_j seems to be referring to, you would ideally have discrete spatial information preserved for every channel in the recording. Do you use the new Dirac ART, and have every channel play the full 20Hz to 20KHz range, and use subs only for LFE, when present? Would that even work to control the room modes? Is there another, better solution?
I am imagining a DBA configured width-wise across a room instead of length-wise. This would give you the maximum stereo subwoofer effect whilst also eliminating room modes. I have never heard of anybody implementing such a DBA. I think @StigErik has a DBA, all it would take is for him to rotate his system against the long wall and he can tell us whether it works.
Room modes do not categorically destroy the effect, according to Griesinger (page 41-45), but most modes are detrimental. He claims that "it is usually—but not always—possible to find loudspeaker positions that work adequately in a particular room."
Yes, I have a DBA with 12 woofers at each end of the room.
Do you mean two separate DBA's in that case, or one where each array acts as the "rear" array for each other? I have no idea if something like that would even be possible to configure ... but could be interesting to investigate. I'm anyway limited to mono bass, since I run bass management in my surround processor, crossing over at 60 Hz.
DBA's seems to be quite directional. I do hear quite clearly that my bass is coming from the front end of the room. If I turn my head 90 degrees to the left, I hear it a lot louder in my right ear. Regular (sub)woofers do not behave like that at all.
Well, yeah, but two channel. Like from the last century.
I think it would be pretty much what @KSTR posted #29 in this thread. Left and right, two channel. The most elementary form, not SOTA.
If I understand correctly, it's something like this, with the main listening position in the middle of the room, and the room also needs to be square?
I apologize for the bad and inaccurate drawing....
No, I am imagining something like this:
(Again, apologies for the poor drawing and poor likeness of you)
Configure the left BA to output left bass + cancellation wave for the right BA.
Configure the right BA to output right bass + cancellation wave for the left BA.
I think both of them should work, at least in theory....
Could be because the impulse response is stretched out in time. While the spaced woofers sum well in frequency with low enough crossover, they still arrive slightly different in time.
If you split the signal from L to the L array in 0 phase (and the R array absorbs) and the signal from R to the right array in 0 phase (whereas the left array absorbs): what happens, if the signal has the same (mono) bass at L + R. Then the right and left DBA will play at the same time in phase and out of phase - would that work?
Good point, but the signal to the absorbing ("rear") array must the delayed and attenuated slightly. So it would behave differently.
I have a small room; therefore, the mains are close to the corners. before I had a sub and finally removed bass from the corners I could hear the bass notes ringing out in the corners. I now have a single sub centered at the frontwall, and the bass is "floating" as it should.
I'm not sure if this would work. For L-only and R-only signal a proper DBA is formed, but as far as I can see for a mono signal we end up with N mono subs all playing the same low-level comb-filtered signal. The cancellation signal for the other channel almost kills the main chain signal as it is an inverted and slightly delayed copy.
I think we really need different and independent traveling wave directions for the DBAs to work and create a proper wavefront for mono signals, traveling from front to back and passing the head on the way. 90 degrees offset of propagation directions seem to be the natural choice then, at least as a starting point.
