A few 2c thoughts/observations....
The assessment of bass directionality needs to be considered, firstly, independent of room. Room vary too much, and tend to be often be used as cop-out with regard to all kinds of audibility assessments, imo.
I think a single sub imparts recognizable directionality in two ways: audible and tactile.
Audible. Steady state tones are the hardest to detect directionality. But that can be true for much higher than sub frequencies too. Sine waves simply don't work at all indoors.
Pink noise low-passed however the sub is set up, sub playing only, is a good test.
Unless the sub is low passed at 80Hz or below, and with at least a 4th order slope, localization is quite easy ime.
I typically use a 96dB/oct low-pass @100Hz. And localization is still easy. But, I'm certain only to a degree that gets masked once main speaker is playing too.
Tone bursts, are super easy to locate.
Tactile. From transients like a bass drop or kick.....again, sub alone. It's a vector from sub's radiating area. It even matters which way the cone(s) are aimed, etc.
I test larger subs a lot, both indoors and out. And room is pretty large, so there are points of circumstance/bias in my assessments.
But honestly, I could care less about studies etc....been doing this too long...and in a bigger perspective than just home audio.
Directional bass rocks.
