- Joined
- Feb 11, 2020
- Messages
- 96
- Likes
- 102
...and here come the trolls ...
Who, exactly, are you referring to?
I was also wonderingWho, exactly, are you referring to?
Sure. Indeed what I showed was done that way!I respect you immensely Amir, but would you consider a REW measurement ‘clean’ if I simply held the calibrated mic in my hand with associated body reflections?
The main domain to EQ are low frequencies and as I explained, the wavelengths are so long that your arm and body are not seen. It is like holding a hair in front of a light bulb. I
The main domain to EQ are low frequencies and as I explained, the wavelengths are so long that your arm and body are not seen. It is like holding a hair in front of a light bulb. It doesn't block any of the light.
It can but no correction at high frequencies should be done with high resolution measurements. Our hearing ERB (discrimination bandwidth) is quite poor so what looks like comb filtering on a graph, is not audible that way. See: https://www.audiosciencereview.com/...ds/perceptual-effects-of-room-reflections.13/Would this not affect higher frequencies?
In addition, if you just move the mic one inch the response changes a ton at high frequencies.
For these reasons, any proper EQ system heavily filters mid to high frequencies and as a result, nullifies any effect
For these reasons, any proper EQ system heavily filters mid to high frequencies and as a result, nullifies any effect of your body.
The whole point of multi-measurements as performed by Audyssey is to not care about any specific location let alone my hand moving a millimeter or two! They are spatially averaged with weighting. No small difference survives that transformatinon.Holding the mic has another possible problem in that it likely won't be 100% stationary, which could affect the response (at all frequencies).
Call me contrary but I actually think Amir should have performed an elaborate dance while holding the microphone through each set of measurements. Surely this would be the optimal way to get the best possible measurements for Audyssey.
Measurements can be a huge trap in acoustics.
Well, that is just one thing. As soon as the wavelength of audio becomes close to width of your face, then one microphone is not measuring what two ears are hearing. Measurements can quickly become useless than way unless great care is taken. One of these days I will write the REW tutorial and explain these things.Are you referring to flat (measured) bass response not sounding good in a room?
Or other things also?
I already showed you proof of this by making my REW measurements at entirely different microphone location than Audyssey (and even a different microphone) yet its modal correction is exactly the same:
No calibration is useful anyway if it relies on your head being in a vice.
You all need to listen to me. Measurements can be a huge trap in acoustics. The proof is in the pudding anyway with post EQ sounding excellent. If what I did was wrong how did this happen?
That is exactly what I explained. The system absolutely does not care if you have the mic 5 inches from your ear or 5.1 inches. Indeed it makes sure it doesn't care by averaging measurements across many feet end to end.I'm talking about (slight) movements of your hand, and so the mic, during each measurement, not between measurements.
Might? I am explaining that the system is designed to not care about such differences. If you don't believe me, then you are arguing contrary to how the system is working. Please read the paper on its design:The result may have been good holding the mic, but it might be even better using the provided (guaranteed stationary) stand.
Objective Function for Automatic Multi-position Equalization and Bass Management Filter Selection
Sunil Bharitkar1, Chris Kyriakakis2
1Audyssey Laboratories, Inc., and University of Southern California, Los Angeles, CA 90064.
2Audyssey Laboratories, Inc., and University of Southern California, Los Angeles, CA 90064.
The spatial measurements are much farther apart than movement of my hand. By definition then their weighted sum will obliterate the micro mic movements.
If you don't believe this, then conduct your own test. Do the calibration with the mic stand and then move the mic 1/4 inch left or right and measurement again. Report what difference it made.
Until then, please, please don't use your intuition on this stuff. This is how those long FAQ threads on AVS went wrong.
And once more, that is exactly what I addressed in my posts. There is no misunderstanding on my part whatsoever.I think you've misunderstood what I'm talking about. I'm talking specifically about slight accidental movements of your hand (and so the mic) positioning during each individual measurement i.e. during each chirp.
