Audiophonics HPA-S400ET or something else? [suggestion]
2. The HPA-S400ET uses the LM4562 OPA, not the TI OPA1656 recommended by Bruno of Purifi. It offers an 8pin socket to put in another OPA model later, but I would rather get the OPA1656 that comes with the Boxem 4215/2E.
It seem like Audiophonics now have changed the LM4562 to OPA1656 in the HPA-S400ET when I look at their website.
I have the older version but recently ordered OPA1656 and swapped the opamps myself yesterday. I actually think they sounded better than LM4562 (more open and airy) but it might just as well be a trick of my mind. Sounds great anyhow!
Is the AUDIOPHONICS HPA-S400ET with a wiim ultra a good match? The wiim will be used for dac/streamer/pre
I use it as a streamer only feeding an RME ADI-2 DAC driving the 400ET in bypass mode and they sound amazing!
The streamer functionalities and especially the WiiM app is one of the best overall. I never used it as a DAC but i think it will be up to the task.
Consider also the rest of your system, especially speakers. the real bottleneck of a system.
I remember from the review and measurements done here that also excluding completely the buffer part it's not having effects on SQ.
I did it just because the RME DAC i have is able to drive nicely the 2 Purify modules without the need of a buffer. The speakers are also quite sensitive at 95dbs, so I'm just using the DAC in its ideal working range.
I expect then swapping the OPamp wouldn't be noticeable. unless something bad was happening with one the two (quite unlikely).
I believe also if someone could hear differences with or without the buffer in a super revealing system, it's maybe the preamp not able to cope with input sensitivity of the modules & not having enough voltage output to properly drive them. Otherwise the impact of the whole buffer board should be very transparent.
OFC is just my2c
Am heading down that same path. I owned the stereo version of what you've just bought (AUDIOPHONICS HPA-S400ET). Really loved the sound but didn't care for the case design although I think they've changed it now (REALLY sharp cooling fins!) and decided aesthetically that 2 mono's look better than 1 stereo in my set up :). How are yours sounding now after a bit of usage?
Amazing, the 2 monos are fed in bypass mode and powering a pair of (upgraded) Tannoy SRM15x monitors. The results it's fantastic!
I plan to buy a lower powered Class D amp (still have to think of the best one) from Audiophonics to feed Tannoys and plug the 2 monos to a pair of a great sounding Brianza Audio Lab classic monitors:
They require for sure some extra juice compared to the old Tannoys.
