Audioengine A5+ Powered Speaker Review
Thank you - a very interesting product
Actually, I'm almost seeing the WiiM as something that could go with the LS50 Meta - basically making your own LS50W (I'm sure there are some compromises) but keeping the complex electronics packaging separated from your expensive passives. I really like the look of this kind of product, will take a closer look at it - thanks.
Absolutely. Passive speakers don't have built-in obsolescence.....they can go on for decades without needing to be replaced. No need to rely on an App to control it or configure it. LS 50 Meta would be awesome choice.
I would go with a Wiim Pro amplifier, and choose some good passive speakers. In terms of ease of use, this is excellent because
1) It has a HDMI ARC port. That means the TV's audio can be routed to the Amp/Speakers. The power and volume of the Amp is controlled by the TV's remote (using HDMI CEC), so it's seamless to use as TV speaker replacement.
2) It handles all the streaming services....and supports casting via Airplay and Chromecast.
3) Supports multiroom audio....just add more units.
Pick a good passive speaker like a Wharfedale 12.1 and you have yourself a great hub for all your music needs and the system acts as a 2.0 or 2.1 music centric system.
Also it has a proper subwoofer output with a user adjustable crossover (a real crossover is missing from most consumer amps until very recently). This is a biggy if you ever want to expand to 2.1. Previously you would have to spend a lot more for either a AVR or something like a Bluesound Powernode for an amp that properly supports a subwoofer.
If you don't want passive speakers, the alterantive would be the ELAC Connex powered speaker. This also has HDMI ARC connection so it is also seamless and your TV will control the speaker's volume and power and can route its audio to the speaker. The Connex has other inputs so you can hook up other audio sources as well if you have a streaming box.
But overall the Wiim Pro is a game changer and seems like the best solution for a one-and-done audio system.
Sorry, I made a mistake in my post.....I was referring to the WiiM Amp....not the WiiM Pro. The Amp has a speaker amp for passive speakers, the WiiM Pro just has line out
Specifically this product https://www.wiimhome.com/wiimamp/overview
began using my A5’s recently after they’ve been stored for several years.
these are the “nonplussed“ version that came out previous to the pair Amir reviewed here.
if you’re used to high-enders, these can seem a little less than clean, clear, and ultra-revealing,
but their even-handed frequency response is okay. i’ve got them a little under one foot from the back wall,
and the left speaker (pictured) is about 1.5ft from the side wall. bringing them closer to the walls seemed to beef
and balance up their bass response.
i’m driving them with a peachtree idac, that has the typical 2V (and with a low output impedance) out from its rca outs.
i’ve added a pair of harrison labs 12db attenuators (you can see them in the pic),
that enables me to keep the A5’s volume control from 10 o’clock and higher.
without them the volume would need to be turned down, which can lead to channel imbalance,
or silence from one channel when taken near all the way down.
What about EQ settings for APO Equalizer Peace? Any suggestions for that app? Using the speakers via a PC.
I'm using APO Equalizer, and according to AMIR, band 300HZ +2db, band 900 -2db, and band 4438HZ -2db
Cause I'm adding 2db to band 300HZ, the preamp setting should be set to -2db to avoid peaking, is that correct? if not, any suggestion is welcome guys, thanks
Special thanks to @amirm, making this little change the speakers sound less fatiguing and more fun :)
This is a review and detailed measurements of the Audioengine A5+ powered bookshelf speaker. It is the one without the bluetooth which seems to have slightly different design (centered tweeter versus not). It was kindly loaned to me by a member and costs US $399 including Prime shipping from Amazon.
The A5+ is a hefty little speaker with very nice gloss finish:
A remote control is included for simple functions (volume, mute, etc.). The business end is in the back:
Unlike many budget powered monitors, the A5+ uses a linear power supply internally (as opposed to a laptop sized external power supply) which I appreciated it. It also eschews class D amps for traditional class AB amplification, hence the large heat sink in the back.
The crossover is passive by the way. This may be responsible for total lack of noise/hiss from the tweeter even when I put my ear next to it. A great benefit compared to a number of monitors which have annoying (but usually low level) hiss.
The slotted port is something I like as otherwise it can be annoying to have air pumped at your face when playing loud.
I should end this intro by saying that I have hardly had a good experience listening to these speakers at shows. They usually put them on a table chest high and play tracks on them which don't sound good to me.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker can be used. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Most important curve here is the on-axis (or listening window) which shows pretty flat (for speakers) response sans a wide valley around upper bass. Whether that is on purpose and part of the amplification EQ or design of the speaker, I don't know. But I take higher bass output when I can have it as I can always turn that down.
We see some peaks in on-axis which survive when measured all around the speaker as indicated in blue and red curves, indicating resonances.
I can't find the crossover spec but would guess around 2.5 to 3 kHz. Around that region we find that off and on-axis responses don't quite match as well as they do elsewhere. There is a waveguide but perhaps is not fully optimized.
Early reflections in a room that are loudest and hence most influential in tonality we hear is not bad:
Putting it all together, we get a pretty good response in a hypothetical average listening room:
The only issue is that recessed upper bass making for an interesting test case of how important that region is.
Distortion tests show that we have a problem around 800 to 900 Hz region:
Problem is there even at 86 dB (left side). We can see the issue in the context of overall response:
I accept distortion/noise in low frequencies but like to see none in the above calibrated graph above that region.
As an aside, as indicated on the graph, these are "in-room" measurements that are then corrected to remove the effect of the room. As such, the graph is free of room modes which corrupts distortion measurements.
The CSD/Waterfall is created thee same way and seems to show the same problematic frequencies:
Horizontal directivity plot shows reasonable response in that axis with rather smooth and broad response off-axis:
Here is a new way to look at the same but just with equal level contours:
The red line is the frequency at which we drop -6 dB. We see that we have better than +-55 degrees before that happens. That gives more freedom to move left and right without the tonality to shift. Given the near-field application of these speakers, this is good to see.
Response is reasonable until -12/+12 dB (pink line). But when we go past that to -18/+18 we see that the shape changes so we lose our off-axis similarity around crossover region but regain it at higher frequencies.
Finally, here is the vertical directivity:
Speaker Listening Tests
I tested the A5+ speaker on my test in the usual left position. It is on a 5 inch or so stand pointing up a few degrees. I have a "2-second" rule with speaker tests where I listen for the immediate reaction to the first track I play. It quickly sets in the impression for tonality. Here, the experience was good! No hand came out of the speaker and slap me to say, "I am too bright!"
That peak in bass was a good idea, providing clean impactful low bass hits. SPL (loudness) capability was also excellent. Yes, I could get it to distort but despite playing only one speaker, it could get surprisingly loud while maintaining that bass response. Gradually though, scratching sound would appear, telling you to back off.
I listened on and a lot of my reference tracks translated reasonably well but perfection was not there. The sound was a bit dull. So I went into Roon player EQ and started to add filters one by one. I wound up with three:
I added that broad increase centered around 300 Hz to make up for lack of energy there. I usually don't like increasing levels in EQ as that can push the speaker and lead to distortion. Not here. The subjective experience was definitely positive resulting in useful low frequency ambiance with almost no impact on how loud the A5+ could play.
Now the sound was a bit bright on some tracks. So I went after the high frequency resonance around 4.4 kHz. Knocked that down by 2 dB and that took care of most of that and cleaned up the highs a bit.
With that experience behind me, I figured I knock out the resonance around 900 Hz which happened to also coincide with peak distortion. Wow, that cleaned up the distortion very nicely without hardly any impact on tonality. You could so easily hear it in vocals and even higher frequency notes. Transient notes because much cleaner and less grungy for lack of a better word. I need to record this effect some day so you all know what I am hearing.
The combination of three filters transformed the A5+ from "OK and good" to "really good!" I sat there listening to track after track, enjoying each one of them. That nice bass was there now together with smooth, balanced response.
You can buy $100 powered monitors these days. So $400 seems quite a reach in the age of commoditization. Fortunately if you care about fidelity, the Audioengine A5+ delivers. It has higher than normal power and bass capability. And with a bit of equalization, produces truly high fidelity experience on your desktop.
As such, the Audioengine A5+ gets my recommendation and changes my opinion of the company/brand.
Since Sir @Thomas savage did not show up for his weed pulling duty during spring here in our yard, I had to buy a truckload of compost to put in our garden to keep the weeds down. The bill? A cool $1000! Needless to say, I feel quite poor now and badly need cash infusion. So reach deep in your pocket and donate what you can using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 4.9
With Sub: 7.3
Spinorama with no EQ:
  • Typical small speaker response
  • Pretty decent all around
  • Should take EQ well.
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Use the Filter 3 to reintroduce the bump around 110Hz
e.g.
Filter 3: ON PK Fc 109.9 Hz Gain -4.79 dB Q 1.27
Change to
Filter 3: ON PK Fc 109.9 Hz Gain -1.79 dB Q 1.27
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
Code:
Audioengine A5+ APO EQ LW 96000Hz
July162025-133856
Preamp: -3.10 dB
Filter 1: ON HPQ Fc 40.4 Hz Gain 0.00 dB Q 1.43
Filter 2: ON PK Fc 278.4 Hz Gain 1.19 dB Q 2.22
Filter 3: ON PK Fc 110.9 Hz Gain -4.79 dB Q 1.37
Filter 4: ON PK Fc 864.1 Hz Gain -2.54 dB Q 1.21
Filter 5: ON PK Fc 2269.7 Hz Gain -2.57 dB Q 1.44
Filter 6: ON PK Fc 5015.5 Hz Gain 1.49 dB Q 1.00
Filter 7: ON PK Fc 4410.4 Hz Gain -2.69 dB Q 5.49
Filter 8: ON PK Fc 9022.3 Hz Gain -1.15 dB Q 1.58
Audioengine A5+ APO EQ Score 96000Hz
July162025-133856
Preamp: -3.10 dB
Filter 1: ON HPQ Fc 40.4 Hz Gain 0.00 dB Q 1.44
Filter 2: ON PK Fc 280.4 Hz Gain 1.08 dB Q 1.91
Filter 4: ON PK Fc 908.1 Hz Gain -2.63 dB Q 1.10
Filter 5: ON PK Fc 2553.3 Hz Gain -2.14 dB Q 1.12
Filter 6: ON PK Fc 3601.3 Hz Gain 1.49 dB Q 2.42
Filter 7: ON PK Fc 4319.3 Hz Gain -3.09 dB Q 3.15
Filter 8: ON PK Fc 10290.6 Hz Gain -1.67 dB Q 1.40
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Small improvements?
e.g.
Change to
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
Score EQ Score +3dB@110Hz: 6.0
with sub: 8.2
Bonus Amirm EQ
Score EQ Amirm: 5.5
with sub: 8.0
  • Audioengine A5+ APO EQ Score 96000Hz.txt
  • Audioengine A5+ APO EQ LW 96000Hz.txt
Score no EQ: 4.9
With Sub: 7.3
Directivity:
EQ design:
e.g.
Change to
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
Code:
July162025-133856
Preamp: -3.10 dB
July162025-133856
Preamp: -3.10 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Small improvements?
e.g.
Change to
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
with sub: 8.2
Bonus Amirm EQ
Score EQ Amirm: 5.5
with sub: 8.0
View attachment 463540View attachment 463539
What APO EQ should i use? I have the A5+ and the S8 subwoofer for my desktop PC. And what settings would you recommend me to use for the sub? Thx!
Score no EQ: 4.9
With Sub: 7.3
Directivity:
EQ design:
e.g.
Change to
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
Code:
July162025-133856
Preamp: -3.10 dB
July162025-133856
Preamp: -3.10 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Small improvements?
e.g.
Change to
will boost by 3dB
Score EQ LW: 5.9
with sub: 8.1
Score EQ Score: 6.3
with sub: 8.5
with sub: 8.2
Bonus Amirm EQ
Score EQ Amirm: 5.5
with sub: 8.0
nice work, I will test your presets out later
