Hey everyone, I'm coming from the Head-Fi forums. I see many people didn't appreciate my measurement method! Understandable - It was a quick/repeatable way for me to see the relative driver response compared to the ATH-M50X driver response. It was not meant to be an absolute frequency response using standardized measurement methods. (The 200-measurement average part is pretty fast. It was an FFT average with pink noise in Room EQ Wizard - not sine sweep after sine sweep. Haha)
I see how people could find my measurements misleading if my disclaimers were not taken into consideration.
THIS is a sine sweep measurement on a CrySound device that is meant for headphone production line testing. Again, it's likely not going to produce the same measurements as a calibrated GRAS/AP system, so I can't say if it's any more useful than the comparative pink noise test I did. Can anyone confirm if planar magnetic driver polarity is typically negative? That seems odd to me.
The flat-plate measurement thing sounds interesting. Wouldn't that be just as useless as a free air measurement without having some baseline reference of how most flat plate measurements look though? It seems to be adding in more variables whereas I saw the free air measurement as a way to remove as many variables as possible.
What is the typical flat plate mic depth? Flush with the plate surface? What about angle of the mic? What about the plate material's acoustic properties? What about the clamping force of the headphones? These are genuine questions so I could make something that will be useful to people.
Here are links to my original measurement posts for context.
You have what is takes to be a "satisfied Audeze customer" :D Just kidding The note saying "Available in several months" is probably just an expression of the distributor's frustration. I still hope to test the MM-100 before Christmas :) The distributor here in Norway still has Oct. 6...
www.head-fi.org
www.head-fi.org
@ squibble: Thanks for showing us your frequency plot. Interesting! I would like to eventually have real leather pads on mine and wonder if the stock pleather pads - imported from the Far East according to Sankar in the video above here - are glued on with two-sided tape like the LCD pads...
www.head-fi.org
His comments were a little harsh, but he made some good points. If the gel-filled protein leather earpads cost more than real leather and are actually higher quality than real leather, why wouldn’t they be used on their flagship model? Why wouldn’t they be used on all of their higher end...
www.head-fi.org
