The user "Gadgetry Tech" also made measurements on Squiglink. They do not look as shouty as the ones we already saw. Still a severe dip in the presence range though.
I cannot say how reliable these measurements are. We are also not told which coupler he uses. Most of his headphone measurements do not look too far off.
Compare hundreds of frequency response graphs between IEMs and earphones from manufacturers like Moondrop, Sony, 64 Audio, Fiio, and more.
gadgetrytech.squig.link
Do you know how to apply parametric EQ? Or do you use a graphic EQ (fixed filters)?
If you use parametric - I just tried it, but I dont own a MM-100 myself, so I cannot test the presets with my own ears.
a) You could try to play around with that gadgetrytech measurement. I used AutoEQ on it from 20 to 10000hz. I got the following results:
Preamp: -11.6 dB
Filter 1: ON PK Fc 31 Hz Gain 6.8 dB Q 0.500
Filter 2: ON PK Fc 230 Hz Gain -1.5 dB Q 1.300
Filter 3: ON PK Fc 1100 Hz Gain -3.0 dB Q 2.500
Filter 4: ON PK Fc 2000 Hz Gain 3.1 dB Q 3.000
Filter 5: ON PK Fc 2800 Hz Gain -5.5 dB Q 3.000
Filter 6: ON PK Fc 4300 Hz Gain 3.0 dB Q 3.000
Filter 7: ON PK Fc 4900 Hz Gain 10.0 dB Q 1.800
Basically, filter 1 regulates the amount of bass, Filter 7 regulates the amount of treble.
I can imagine that these two might be bit much here, especially Filter 7 (10db) seems like a lot. You can reduce them if it sounds harsh.
b) I also tried to built one from the scratch, based on all the measurements I have seen until now. This preset should be rather safe, in the sense of "do not change more than necessary". It is likely far from perfect but I except it to be an improvement over default.
Preamp: -5.8 dB
Filter 1: ON LSC Fc 100 Hz Gain 4.0 dB Q 0.700
Filter 2: ON PK Fc 230 Hz Gain -1.0 dB Q 1.000
Filter 3: ON PK Fc 3300 Hz Gain -3.0 dB Q 3.000
Filter 4: ON PK Fc 5000 Hz Gain 6.0 dB Q 3.000
Filter 5: ON PK Fc 7000 Hz Gain 2.0 dB Q 4.000
Filter 6: ON PK Fc 8500 Hz Gain -2.0 dB Q 4.000
