trevor_bartram
- Joined
- Dec 29, 2021
- Messages
- 54
- Likes
- 12
When I said I have a similar HT system using Missions, it's the same AVR etc in a much larger room. Do you have any passive speaker recommendations?I find that intelligibility in small rooms is typically impacted by nearby reflections, which can be helped with a speaker with narrower dispersion. You may find that an active monitor with a large waveguide like the LSR 308 or 306 or 305 or the Kali LP 6-8 would help more. As you may have noticed, simply increasing treble doesn't help clarity very much.
The 'shape' of the speaker's dispersion has a lot to do with clarity, more than simply how loud the treble and mids and bass are, and the Ascend speakers here are not fundamentally that different from the Snells - maybe a bit better due to the smaller woofer, but a waveguide is best for a small room.
I do like the sound of the Kef LS50 Metas based on YT listening tests of many speakers, if that's a clue to my sound preference.
