mononoaware
- Joined
- Apr 6, 2021
- Messages
- 816
- Likes
- 681
- Thread Starter
- #81
Headless M1 Mac Mini Setup:
Firstly signed in with Apple ID since this was required for the iOS iTunes remote App, then spent a lot of time un-syncing iCloud and deleting all traces of what was synced.
Just left “Find my” on, then updated to Big Sur (this took longer than I expected, maybe I’m spoiled with the speed of iOS updates).
After the update finished I turned on “automatically update” (under System preferences>Software update) and checked every box (“auto install updates” etc).
Then after configuring some “Apple Music”(previously iTunes) application preferences (disable auto-add/convert to iTunes folder etc), I proceeded with “Migration” using hard-wire Ethernet cable following Apple’s instructions.
On Windows I moved just the audio archive folder to the empty “Videos” user folder so nothing extra was slowing the transfer.
(Migration only gives you the main user folder options, you cannot go into sub folders and select them).
One thing I noticed though was the countdown (around 30 mins) didn’t change at all, but it finished in around 15 mins (80MB per second transfer speed according to Migration).
I thought Migration would save me from having to copy twice (like you would with external drive) but turns out every time you use ”Migration” it creates a new Mac user account and you have to go through the process of “sharing” the files to the main “Apple ID” account and changing the read & write permissions of the folder to “everyone”.
Actually I had to copy 3 times: Windows>Mac(1)>share folder(2)>music folder(3).
Hopefully the last 2 times it just changed the directory instead of actually “copying” the files.
I then deleted what was in the shared folder and deleted the extra account.
After migration was finished I turned on the Security&privacy>built-in Firewall.
After dragging the folder into Apple Music which was quick and painless, I created playlists identical to that I had with iTunes on the windows machine.
This took a few hours, mainly because I create a playlist for every other album with tracks omitted.
Next plugged in the DAC via USB, turned on the DAC and switched it to USB input.
Mac recognised it, then I went into Utilities>Audio MIDI setup and set desired sample rate.
Interestingly 32-bit is greyed out, so that’s the only bit-depth choice with “Core Audio”.
Played back some content to make sure it was working.
Now for the next hurdle: iTunes remote iOS App (Connecting iOS remote to Mac).
Had trouble trying to connect using the “Manual” option which Apple Support website recommends to do for the first time.
After researching and troubleshooting, I got it to work by enabling “Home sharing” (under SystemPreferences>Sharing>media sharing), and tapping on the “Home sharing” connection method of iOS iTunes remote App screen.
This allowed it to connect straight away and control local playback on the Mac.
Before going headless I set the Mac to Users&groups>auto-login, Security&privacy>require password to never and added “Apple Music” as a log-in item (auto-open after login).
I tested it quickly and it works and the HDMI virtual dummy plug is arriving later today.
I think I covered everything, there are a few things I could have done better but this was my first time using a Mac so it required a lot of back and forth to look up “where is _____”, “what is the equivalent of Windows _____ on Mac” etc.
I will give another update after some extended use.
