That combo of the coax with a 10" woof will make it honky sounding and nasal'ishy too?
I wouldn't assume that, it's just a weird speaker. Like, the cone becomes a waveguide for the tweeter right? And generally as a rule of thumb, for the waveguide to match the woofer, they should be around the same diameter. You see this with most speakers - Gedlee Abbey has a 12" woofer and a ~13" waveguide, lots of speakers are 7 and 7, you get the idea.
So in theory, if the cone is shaped right, it can function as a WG for the dome, and it will be approximately the right size to match with the woofer, because the woofer is the same size as itself.
Using a big woofer you get other benefits, too. For one, you can use a bigger voice coil, so you can put a beefier tweeter inside the woofer. Also, the area of the woofer is really big, so you're not sacrificing a ton of radiating area and turning your midwoofer into a mid (cough cough KEF).
If you
do have directivity mismatches, putting the speakers inside of each other tends to make things work well, since the relative path lengths to the acoustic center of each driver are very close, so off axis response is going to be drama free if not exceptionally controlled. Having said that, a 10" woofer is pretty controlled in radiation, and the tweeter is in a big ass waveguide, so maybe it will have really tight directivity?
So, it's easy for me to see some upsides to this idea, but there are some pitfalls. One, this strikes me as a hard speaker to get right - but Andrew Jones presumably knows something about manufacturing coaxial speakers. Two, there's the simple issue of output. A 10" midwoofer has some serious power potential, even if it has low efficiency and a low Fs and the rest of it. A little tweeter stuffed inside its VC, on the other hand? Maybe they pulled it off - maybe the dome is actually quite big, and the horn loading helps, and they're using a beastly little neo motor. Who knows.
In conclusion, I don't think Andrew Jones is a better speaker designer than, you know, KEF or ME Geithain, and I find the use of his name as a marketing tool to be...strange, given the collaborative nature of modern engineering. Like do we really have Saul Marantzes and Winslow Burhoes and Dave Wilsons today? Having said that, he has a track record of making innovative and performant speakers, so I will just say I am looking forward to seeing the measurements. If this speaker works, it's a really cool design, and a great way of packing a ton of radiating area in a small box.
