What kind of value of cap would they use?Many powered subs also have speaker level inputs which incorporate an inbuilt HPF (in the form of a large BP electrolytic cap) on the speaker level in/out terminals.
That makes it good for up to ~625Wrms @ 12.5Apeak. That's generous. I don't see those caps failing anytime soon if quality caps.150uF and up. 220uF I've seen. Somewhere on ASR, I swear I took a pic. Here it is:
BP 150uF/100WV. That'd give approx -3dB@130Hz on an 8R driver.
I haven't worked on many subwoofers and most of them that I did had a IC for output; the easy stuff. I worked on a couple of Velodyne and thankfully they never had a servo issue because I was flying without a service manual.Pretty much wun hung lo brand, but good enough I guess. The glue will hold them together. LOL.
Et to Brute!Of course you can augment the bottom end of loudspeakers with a powered subwoofer. Many powered subs also have speaker level inputs which incorporate an inbuilt HPF (in the form of a large BP electrolytic cap) on the speaker level in/out terminals.
Et to Brute!
I thought you would understand how a crossover works and what havoc your suggested set-up will create to FR.
A sealed enclosure speaker is a 2nd order HP filter at its f3. Similarly a vented enclosure speaker is a 4th order HP at its f3. When you put a capacitor in series you will cascade a 1st order HP filter, creating a 3rd (closed) or 5th (vented) order HP filter. This is physics.
Now shouldn't we ask those manufacturers: how do you know my speaker type or f3 that a fixed capacitor is used and why there is no setting for sealed or vented enclosures?
Manufacturers do things that has no engineering sense. I believe ASR tries to do stop them. We should help the cause as much as possible and question them.
I though I explained using engineering terms. I agree that it is not rocket science but how speakers behave is science.What on earth are you talking about?
What about the lady delivers a subwoofer, nicely dressed ofcourse.
If you are genuinely interested you may want to re-read my post and ask specific point you disagree on. Meanwhile, I have not defined the size of any speaker, as it’s irrelevant to a crossover.Tell me about your powered/unpowered slugwoogers to compliment those mini monitors? What was so groundbreaking? Genuinely interested...
A cross-over as the the name suggest is a combination of cross between a LP and a HP filter. Both filters must have the same frequency in order for a cross-over to work. Here is a layman explanation.Isn't the crossover to the sub set well above the innate roll-off in most installations? I am not sure how f3 plays into the crossover from mains to subs; the crossover should be an octave or two above the HPF filter function of the sub's low end response. Unless trying to mix ported and sealed subs (blah) I have rarely worried about the subs low-end rolloff, focusing instead upon the crossover to the main speakers. The usual trick is to align phase at the crossover frequency for subs and mains, which a standard L-R circuit does nicely.
Far too expensive!View attachment 217925
Parasound has you covered.
Not an integrated amplifier.Or just use a MiniDSP...
Far too expensive!
I apologise, I guess it is an integrated amplifier but without any analogue input its use is limited. However, that is becoming less of an issue as the time progresses.SHD Power
Roon Ready streaming amplifier with Dirac Live® room correction, 2 x 120Wrms power amplifier, miniDSP audio toolbox for subwoofer integration, Volumio music player, 450MHz Sharc DSP processorwww.minidsp.com
