The connector suggests this should be possible (4-pin mini XLR) which means it won't accept 3-pin mini XLR.
The strange thing is that the 3 cables that come with it are all TRS.
However, as this is a BT headphone as well it is highly likely the - of both drivers are connected making balanced impossible.
Maybe the plan was to also use the K371BT's microphone and maybe even one button remote using a 3.5mm TRRS but ditched the idea.
Maybe AKG plans to launch all future headphones with 4 pin connectors so owners can use headphones balanced as well... maybe AKG saw the balanced light ... finally.
We might know when new headphones come out.
I would guess one pin is not connected though.
Hi @solderdude
Does the K371 (not BT) stock cable have all 4 conductors insulated end to end?
No shared 'ground' after the 3.5 plug, to the other end?
I know it starts with 3.5mm plug at one end and ends in 4-pin mini XLR at other end but don't know if conductors are all insulated all the way between ?
