DualTriode
- Joined
- Oct 24, 2019
- Messages
- 904
- Likes
- 595
That level of difference and then some shows up in differences between left and right channel. How you wear the headphone is liable to be different than how it fits on the fixture as well. I can't believe you all put so much stock in such minor differences that may or may not be real or representative of actual use.
Seems like no matter how strong I make the disclaimer at the start of these reviews, I can't unhook you guys from the attachment to graphs to this degree. I give you a yardstick graded in inches and you all keep focusing on a fraction of an inch. Never mind that each yardstick is different then others by +-1 inches if not more, and so are the items under test.
I am going to suggest that such complaints be taken to headphone complaint thread.
@amirm,
Your measurements are completed with Laboratory Standard instruments to Laboratory Measurement Standards.
Your disclaimer does not carry the same weight as you measurements.
I for one do pay attention to your comments.
Solderdude, I do not know why you persist. Your measurements are not done to any recognized standard; they are made on your own DIY measurement jig “calibrated” to your own DIY equalization curve.
