SonicSleuth
- Joined
- Apr 7, 2023
- Messages
- 45
- Likes
- 26
See conceptually better. Imo..
Wholeheartedly agree. Can't wait to drop it into another custom all-billet case.Yes all good things, thanks for keeping us informed! nice to have the option of RCA / XLR unlike my current DIY TPA3255.
Hope the sub out is controlled by volume with some kind of filter.
They need to do away with the dated and frankly cheap fonts and graphics near the volume knob, everyone knows how to use a volume knob, it gets louder when you turn up and quieter when you turn it down. Some subtile dots, beginning center and end would be fine. They GOTTA up their game, looks matter! Why make a product LOOK cheap when you can make it look premium, with nothing more than a little thought?
An example, simple design, modern fonts, no fluff.
Looks to have some kind of rotary knob on the rear too, balance? I have channel imbalance I have to alter it on my WiiM Pro 0.35 to the left to get centered image.
Hmm LM4562 wonder if those will go on my TPA3255 260-2-29A board. No sockets though and they're balanced ones, does have a single ended mode though.I swapped out the factory op-amps for LM4562's
More detail and separation of vocals/instruments with these little jewels
Can you just run a volume pot with that board?Hmm LM4562 wonder if those will go on my TPA3255 260-2-29A board. No sockets though and they're balanced ones, does have a single ended mode though.
You should insist: what people need is an adjustable high pass filter, most subs come with an adjustable low pass filter.Sub-Out Volume Control with Volume Knob - YES
Low Pass Filter - Probably Yes, adjustable LPF
Curious if the volume control knob will integrate the power on/off switch?Adding in some details here for Aiyima's TPA3255 PFFB Amplifier, few things I could confirm with Aiyima:
Capacitance - 63v
PSU - External, probably default would be 48v GaN
Stereo only, or mono/stereo - mono/stereo switchable
Availability - Most probably in March 24
I think YES, however I don't like it personally.Curious if the volume control knob will integrate the power on/off switch?
Even though we can max out vol pot to minimize its impact (if any) but me too would like amp without fussy volume control to avoid any unnecessary component out.I’d like to see a switch to set the gain to use these amps as a pure power amplifier, or a non volume controlled version
I am looking for a small setup of amps to be used with active speakers and a Dsp
Fosi wants to implement PFFB in new mono and stereo versions of the V3:
https://community.fosiaudio.com/threads/v3-mono-with-pffb-coming.38/
I guess they implemented PFFB on their own designs. The 3E board would be too expensive.Yes, Fosi have mentioned it in a few posts as well.
But is it their developed module/amp or whatever they have been buying off the shelf like 3e or Sylph module?
Anyways, looks like some good projects are coming up soon.
That’s really cool if @Fosi Audio have done it successfully on their own.I guess they implemented PFFB on their own designs. The 3E board would be too expensive.
