3e Audio A7 - TPA3255 Stereo Amplifier Advanced PFFB -First Look
The overall design of the case looks good. The front button and rear connectors look good and are well placed.
The heat dissipation still seems problematic:
  • When these TPA325x chips get hot, they start to degrade in performance, output power, and lifetime. A big part of the success of the 3e audio 260-2-29A PFFB module design was the huge aluminum heat sink under the board.
  • Using the amplifier box to achieve the same effect can work, but care must be taken to provide a reliable interface between the chips and the box.
  • A strip of U-bent aluminum between the chips and the box and a few dabs of thermal grease won't do the trick.
I'd like to see a preliminary reading with an infrared thermometer pointed at the TPA325x chips and the top and bottom plates of this case. If the case does not get hot, it is not a good heatsink.
someone will test it soon i believe,we put bigger heatsink, more air slot on both side and also bottom side, our evaluation is better then other brand(PA7 Plus and V3mono)
Well, it clearly has a 12v trigger
Yes, and it's a pre-production sample, as has been mentioned before. :)
@3eaudio explicitly confirmed that the trigger input has bee dropped for the regular mass production units in their own thread:
