This is another formal listening test published at Audio Engineering Society Convention on differences between high resolution formats: http://www.aes.org/e-lib/browse.cfm?elib=13185
Differences of Hearing Impressions Among Several High Sampling Digital Recording Formats
Toshiyuki Nishiguchi, Kimio Hamasaki
NHK Science & Technical Research Laboratories, Tokyo, 157-8510, Japan
[email protected], [email protected]
Presented at the 118th Convention
2005 May 28–31 Barcelona, Spain
The Abstract tells the whole story:
"To study the difference of hearing impression of recorded sound among several high sampling digital recording formats, we conducted subjective evaluation tests. Perceptual discrimination was evaluated among the following digital recording formats: 24 bit/48 kHz, 24 bit /192 kHz and DSD.
The sound reproduction system for the subjective evaluation tests was carefully designed in order to reproduce the highest quality of sound on each digital recording format. Listening panels were selected from students of a university of music, recording engineers, and musicians. Sound stimuli for the evaluation were originally recorded to have exactly the same quality of analog signal which was fed to different A/D conversion systems. The results of subjective evaluation using pair test method showed that the sound quality of the auditory frequency band in this experimental system might not depend on the sampling format."
Here is the setup:
In other word, parallel capture of a live session into three formats: 24/48, 24/192 and 1x DSD.
Nice confirmation of the ADC/DAC bandwidth:
And the results? Another buzzkill:
"The six subjects completed listening tests consisting of
24 pairs on three different stimuli in which they
evaluated each pair. The results showed no significant
difference. This means that the experiments could not
identify any subject or any stimulus that might show a
significant difference among the digital recording
formats."
Note: the test lacks statistical analysis. The paper doesn't have sufficient detail to perform such an analysis. In vast majority of test cases however, the % right was below 50 so their conclusion is likely correct.
Here is the setup:
formats."
