Sorry, I didn't mean to hijack this T8V thread with yet more Dirac talk, but I'll carry on as it's partially T8V relevant
Generally I'd agree with that. So, I decided to re-run it. Turns out the USB extender I was using in the UMIK mic wasn't do the business. It's a 12m cable run to the machine room. I was just unlucky that in the three attempts I made, it messed up on the T8V every time and not the BM....! Different extender in place, but same procedure; results are much more similar. [I remember this happened to me years ago when I first played with Dirac. I recorded the mic's output and could clearly hear it glitching. Weird it doesn't throw errors in the OS/DAW but there you go. I probably picked up the same extender that's been on the shelf since then. And I'll probably fail to throw it out and do the same again in another 5 years time
For what it's worth, the main 7.1.4 monitoring chain in that room does include Dirac in the form of 2x MiniDSP DDRC88s and I'm happy with it. It took me a few goes to begin, through both trial and error of mic positioning and target curve refinement. I also tried Dirac and Trinnov when the room had 5.1 only. Trinnov was kinda the same deal. I do have a "No Dirac, Manual PEQ-only below 200Hz" preset, but I think while it's a more fun listening experience, I'm confident the filters the Dirac's made are a better reference point for mix translation.
Oh and yeah, I have no idea about Dirac's predicted response either. It looks bonkers. Whether it's the case or not, it makes me *think* it doesn't "understand" what's way outside of minimum phase and just tries to flatten the whole lot. Then when you measure the results, you still see the same nulls because, well, they're basically unfixable of course. I guess you could prove this by measuring electronically before and after without a room in the system. Amir says it does try to fill in response and I'm inclined to agree.
Anyway, back to the T8V. The BM15 and T8V, while spectrally "the same" post-Dirac, the BM still sounds more "open". This is now going a bit beyond what I set out to test now, the answers to which are: (1) The T8Vs sound great for this price point (2) They handle low frequency "abuse" (In my case, "use") better than I expected given the relatively low power amp ratings, but they'd really need another 6dB of go on them [in that room] to reproduce full dynamic, full-band at theatrical reference level, at 3m. [That's not a criticism, this is nearfield speaker...] In reality, even at that distance they'd probably be passable for most programme material at "85dB" ref but you could certainly saturate them doing bass drops and so on. There's not really a fixed reference level for Home Entertainment any more, but since it's typically it's mixed between 3 and 10dB down on theatrical, they'd definitely cope with that in real world use.
But.... One observation of the very limited measurements I have here are that the phase measurement for the BM is smoother against the T8V, which is stepped. Dirac makes those steps wider and hence deeper. I wonder if this difference is an audible thing?
Here's a bit of an unwrapped graph (T8V in green, BM in blue). It's more obvious across the whole range but you'll get the idea... Side note, both speakers are just off-centre (one left, one right) and now behind an acoustically transparent screen as I wanted to see if that interacted with the HF in any different way between the waveguided T8V and basic soft domed BM... It didn't. Or rather, it didn't within what I can hear/measure.
Thank you!! (So much knowledge here; great forum!)
