DDF
- Joined
- Dec 31, 2018
- Messages
- 617
- Likes
- 1,360
So you mean they are the Dalis of monitors
Maybe Dali knows what they're doing too.
Here's another example but done the opposite way, an old design trick I use sometimes to help smooth out the PIR while keeping on axis flat. This is a design I made ~ 30yrs ago (original was 8543/Vifa tweeter, now is 8545/Usher tweeter) with a 15 degree slanted front baffle (bit hard to tell in pic, but similar to Kairos):
Using a tweeter a bit hot up top on its axis and tuning the crossover to be a couple dB hot through xover at +15 degree vertical (90 degrees to the baffle) gives a nice response on the listening axis, and is still very nice standing up
Big benefits in directivity matching similar to what we're talking about but beyond:
- a better match between the listening axis and the power in room through xover
- delivers extra very high frequencies into the room while using a larger dome. This achieves higher power handling than a small dome (and ability to cross lower for further improved directivity match) while delivering some of the benefit of a smaller dome's greater very high frequency energy into the room
taking it a step further:
- steering the crossover null towards the floor allows that standing position to be pretty flat. Most designs amir measures seem to point the lobe forward which causes a big dip in the mids when listened to standing up
- the baffle tilt also provides more time alignment allowing some lower order xovers which can also be used to further smooth out the directivity mismatch
Linkwitz took the concept to its extreme with his lx mini by pointing the woofer directly up but had to stick with a small woofer to pull it off.
A few older commercial designs tilted a larger woofer up 45 degrees to try and maximize this balance between on axis and PIR. But this results in too much reflection and diffraction off the baffle with short time delays that hurts the perceived direct response, so I found it better to use baffle tilt and toe in the speaker to achieve much the same thing without the reflection drawbacks
