On the matter of analog vs digital active xo, one point is often missed by newbies.
When newbies build analog active crossovers, they almost always build "stock" crossovers, i.e. textbook "knee" and slope, or textbook values of Fc and Q. These are also the builders who get attracted to Rod Elliott's PCBs or Marchand Electronics boxes. These builders never measure their speakers, or even bother to take the manufacturer-published SPL graphs, digitise them with graph tracers, and then put the FRD data into something like VituixCAD with the active crossover schematic.
Needless to say, these builds show problems later because of phase mismatch between drivers at crossover points, since drivers are rarely perfectly linear at the crossover frequencies. This means that when you measure the acoustic output of your crossover + drivers, using a mic, you'll see dips and peaks, and the sound will be coloured. This requires correction with parametric eq.
This is where analog active xo is worse than digital. A single channel of parametric eq can take 4 opamps, and even an analog notch filter can take between 1 and 3 opamps, depending on the Q you need. The tenacious builder will add all this extra circuit to the inputs or outputs of his analog active xo. Most newbies will simply not bother, and will marvel at the clarity of their new speakers and talk about veils being lifted. In reality, the veils being lifted are colourations caused by the peaks in the SPL graph.
In this area, I find digital active xo to be superior, because you can simply throw in a few channels of PEQ as and when you want to "tune" the sound, either with your own ears or with the help of a techie friend who may actually know how to measure speakers.
Rod Elliott (who I respect hugely, I feel he hasn't gotten the respect he deserves) too leaves the newbie speaker builder high and dry here. In his entire website, I've never seen any mention of actual speaker response SPL graphs, and how the xo modifies those graphs. Since I have some experience in speaker design, I am very happy to use his lovely 3-way active xo PCB, but I'll throw away all component-value-calculator spreadsheets, plug his schematic into VituixCAD and tune the R and C values after adding the speaker driver FRD data and optimising the simulated output.
Newbie speaker builders need to understand that stock crossovers, whether active or passive, almost always make mediocre speakers. And PEQ is the great blessing of digital active xo for such builders.
