At another forum, someone gave me this list of OS to try:
Moode
Volumio
Archphile
CollybiaOS
PiCorePlayer/LMS
Gentooplayer
Rune
I might test them all
Also...
https://ubuntu.com/appliance/plex
Moode
Volumio
Archphile
CollybiaOS
PiCorePlayer/LMS
Gentooplayer
Rune
Not previously mentioned because Ubuntu's appliance line have only just appeared I think. Plex has been around for some time. Can't comment on what it's like as I've never tried it.
I always got the impression from the web site that you needed to sign up for an account to use it, which put me off. Is that correct, or did I just misunderstand? When I looked I was using LMS and MythTV anyway, and it looked like I'd have to pay to get equivalent capability so I didn't bother trying it.Yes, that's why I thought i'd mention it. I've run Plex for many years (I bought PlexPass Lifetime in 2013) and the music side has been enhanced significantly over the last few years (integration with Gracenote, separate music app, etc.). I don't use Plex often for music, but when I do, it seems to work fairly well.
You're right about the sign up, it's necessary.I always got the impression from the web site that you needed to sign up for an account to use it, which put me off. Is that correct, or did I just misunderstand? When I looked I was using LMS and MythTV anyway, and it looked like I'd have to pay to get equivalent capability so I didn't bother trying it.
You could try PiCorePlayer running LMS with the WaveInput plugin. I haven't had cause to try it so can't say for sure that it would work.Let me try this here: ADC and R4.
I like to add a ADC board (like from HiFiBerry) to digitize Vinyl and send it out of the HDMI port, to be fed into a Dirac DRC unit. It seem that only Volumio can do that, HifiberryOS can not. But Volumio charges 60€/a for that! Are there other options? Via USB?
Which Pi to buy in 2020?
My system plan is to feed the signal into the Topping E30 DAC (DAC only bypassing the internal pre-amp) via USB or coaxial.
The RCA out from the DAC would go into the Musical Fidelity power amp via a tube pre-amp and eventually to the three-way speakers.
So the question I am mulling over is which Pi device to buy?
Pi3B is powerful enough to to the streaming job, feed on half the power, generate half the heat and electric noise / interference?
Pi4B is more advanced (is it really needed for music application?) need a fan, better power brick, better implemented USB, however can be equally configured to choke.
So if I am to use the USB connection to Topping E30 DAC which device choice is better? Pi3b or Pi4b?
Would the allo Digi+ One HAT improve sound quality having it connected via coaxial to the same E30 DAC? And should I make a different Pi purchase in this case?
I know there are numerous ways to skin a cat but either way you would need that poor cat.
A great harmony has broken out as we all sing from the same hymn/song sheet.Which Pi to buy in 2020?
In total agreement with this. We need to put to bed the nonsense that an RPi configuration alters sound quality. Issues in functionality are not issues in SQ, they are about whether or not things work! When connected to a good DAC (which the E30 definitely is) you will have no problems with SQ whatever set up you go with. Rule of thumb with an RPi - if it costs a lot, it's probably unnecessary (but spend a tiny bit extra on a decent case!)Darko would have you believe the Pi USB sounds "metallic" compared with the Allo DAC. Needless to say this only further convinced me to go USB because... Darko; and as somebodyelse said, a hat limits your choice of cases.
Thank you all for the replies, much appreciated.A great harmony has broken out as we all sing from the same hymn/song sheet.
