sysfc6
- Joined
- Jul 2, 2023
- Messages
- 152
- Likes
- 17
Is the 150 better for long distance listening than the 310?H
对于这种距离,我推荐KH150。只有当你听的音乐有低于40赫兹的重要内容时,你才需要KH750。很少有音乐是有内容的。
The KH750 extends the low frequencies but does nothing to make the KH 150's louder or more suitable for medium or long distances.If you add a pair of 750s to go with them, would they be suitable for medium to long distance listening
So is your advice to buy 150 plus or minus 750? or to buy 310 plus or minus 750.? Or just buy 420?在我的KH310系统中,主听音位置大约是2.7米(中场),效果非常好。
诺依曼网站specs上说KH310/KH150都是0.75m - 6.0m的好;而你的2.5m在推荐距离内。
Can Orisun replace the 750? I have a RythmikL12 will it replace the 750.How is your subwoofer working?You should do your own due diligence.
If you ask my advice:
- first choice = if you have the budget, just go and buy the KH420 (which already includes 10" woofer)
- second choice = the midrange dome is really good, so buy the KH310 + subwoofer
- third choice = KH150 + subwoofer
^^ for my case, I did not buy subwoofer from neumann, i re-used the Orisun DD+12 push-pull subwoofer that i already own.
I also have observed some shrillness of the KH120. My interpretation is that the wiggles of the di from 1.5kHz to 4kHz are not good. They are almost exactly in the wrong direction.The shrillness is probably not caused by the tweeter but the woofer. I found one particularly shrill piano note from the sheet music of a piano piece. The fundamental of that note is at only 349Hz, meaning this note does not activate the tweeter until its sixth harmonic. My theory is that, when holding the tweeter and sub constant, the combination of a dome and a big woofer is better than a small woofer. Quite an obvious explanation, isn’t it? But it isn’t so obvious in the CEA2034 data.
I have just participated in a program on the French public classical music channel France Musique during which we compare several interpretations of the same piece of music.On my KH310 setup, main listening position is about 2.7m (midfield), and it works very very good.
Neumann website specs says that both KH310/KH150 is good for 0.75m - 6.0m; and your 2.5m is within the recommended distance.
If someone has the courage: let them go and listen to Kryztian Zimerman in Debussy's La Cathédrale gloutie, Préludes Livres 1... Horrible... and very instructive...
... and still sound better than most similar sized 2-way and 3-way speakers, regardless of the listening distance. I run a pair of O300D (predecessor of KH310) at 3.8m distance in a 50 sqm room, accompanied by a Genelec 7060b sub and they sound fantastic (also without sub).Neither are designed for long distance listening. They are designed as nearfield monitors.
Yes... and also Ce qu'à vu le vent d'Ouest...This one?
Krystian Zimerman - Debussy: Préludes / Book 1, L.117: 10. La cathédrale engloutie (Live)
Listen to Debussy: Préludes / Book 1, L.117: 10. La cathédrale engloutie (Live) on TIDALtidal.com
There is the problem that you will never get a high amount of direct sound with distances beyond 2.5m. Even 2.5 is a stretch it might slight fit with an overdamped room. 1.3m Listening distance is about the best distance in a standard room. The potential lack of direct sound is not good compared with a proper listening distance it is much more important to choose a speaker which does this right over getting a speaker which looks better "on paper".Do not let people deceive you that at 2.51 meters, the sound will be substantially degraded.
I trust Neumann engineering team when they spec the KH310 for 0.75 … 6.0 m![]()
Do you mean, 2.5 meters choose 420, not 310?问题是,在超过2.5米的距离内,你永远不会获得大量的直接声音。即使2.5米也是一个延伸,它可能与过度阻尼的房间略有出入。1.3m的听音距离,大概是标准间的最佳距离。与适当的听音距离相比,直接声音的潜在缺乏是不好的。选择一个能做到这一点的扬声器比选择一个“在纸上”看起来更好的扬声器更重要。
Yes, definitely KH420 for that listening distance. I personally would even consider slightly bigger speakers. It depends on the room acoustics. In an average threaded room a slight bigger speaker should be better.Do you mean, 2.5 meters choose 420, not 310?
