Greenway54
- Joined
- Jun 12, 2025
- Messages
- 7
- Likes
- 2
- Thread Starter
- #21
Not sure about the 'not a super great value' reference...I paid $1260 + taxes CDN for my JL Audio D108, and the SVS 3000 micro lists at $1500 + taxes, but maybe you were suggesting the D108 is not a great value in terms of relative specs/performance. Anyway, I get the point that there might be a deal on two. That being said, I already have one D108, so any move to two subs would mean a return to the local store that sold me the first one (where I originally went to buy an SVS 3000 Micro but I favored the D108 instead after checking out their stock).So, I run 2 subs with my genelecs in my office, but they're in the corners and not right under the mains.
I will say that the D108 is not a super great value unless the size constraint is insurmountable. @sweetchaos has put together a pretty comprehensive list of subs and their tested performance here: https://docs.google.com/spreadsheet...6ZL6anVTW2_M/edit?gid=834598950#gid=834598950 - I think you can't really get small, cheap, and high output, but the SVS 3000 Micro is worth a look as an alternative, as they give a deal on a pair of subs, it's slightly smaller than the JL unit, and the output is similar.
I have 2x BIC F12s, I got them used for $250 total, and one of them beats the D108 @ $1K USD. So if you can lose the size constraint somehow, there are deals to be had.
Aside from that, I definitely recommend running EQAPO on your PC, you can EQ the bass to perfection, it's really the best upgrade you can make for small dollars. (EQAPO is free but you'll need a mic.)
