I tried Amir's settings in some program, I forget which, Roon? loon? whatever it's called. Did not like the way it sounded. I've tried others in the past, like foobar, Winamp, an old stereo, etc. It'll sometimes be the case that I initially like my tweaks, dropping treble down, only to find out later that another piece of music sounds better with the EQ turned off. There's also a lot of ear adjustment that goes on, psychologically, where you think you like something, and then next week you try your EQ settings again and wonder what you were thinking, and you just prefer it left off. I'm sure a lot of people have had that same experience?Ah, the analog "purity" idea.
If you delve deeper here, I think you'll come to see that it's simply impossible for designers to make a speaker or headphone follow the exact curve they want, solely analog. They can get very close, but there will always be physical limitations only DSP can solve.
Have you done 10 band PEQ, or are you just using graphic EQ by ear? The former always makes a larger difference than the latter, especially when assisted by tools like AutoEQ. Either way, make sure your reference is good. A very large amount of music is actually pretty useless for helping with EQ. You want sound evenly spread out through the frequency range, like pink noise. Some very busy genres, when well recorded, like fast classical, rock, or metal are good for this. Tracks you know particularly well can help of course.
This is just my understanding so far. I try to refine my methods and knowledge as I go.
Still, I agree that certain frequency responses make sense for certain situations. My main point is PEQ can refine anything, whether you're going for the Harman Target, your own custom curve, or improving the stock curve to your liking.
But I'm not talking about whether flat is bad, I'm talking about how there's more to a headphone's sound than the frequency response, and how you can't just EQ every headphone to sound the same. It's absurd. For instance, a V or U-shaped response tends to result in a more spacious sound, so it's there on purpose by the headphone makers. It creates a more enveloping sound. And it's hard not to think that the driver's design or selection, as well as the pads and cups and other features, weren't based around that too, in many cases.
