Do you know some good examples? Is there high quality material of interesting music available?
But this will come for sure and reverb algorithms will probably use all of the channels, that's very possible!
@test1223 - wide high frequency beam is one of the great things of KEF coaxes! They are actually wider as many normal speakers. The feeling of being surrounded by the sound with a 7.1.4 system ... doesn't need to come from reflection smearing, you have enough speaker for that ;-). So I would prefer a precise reproduction and controlled acoustics.
@Keksstein For real high power and wide dispersion you would use Bliesma T34A or T34B. These will be louder and with less compression as all the tweeters you have in the speakers you think about. I went the compression driver way in my cinema and found very nice units with no resonances up to 20kHz and smooth, "soft" sound (cause I have my listening room for analytic/"real" listening).
T34B can even be used with a waveguide, T34A is for very wide and even radiation up to very high frequencies. You can combine that with M74 and put a few 12" underneath. For a freestanding "endgame" speaker I would use 4 (2 on the backside), for on/inwall 2. With a wavegudie you could also use a PHL Midrange driver but there are not many which can do that SPL level.
I use such a concept for a custom speaker with a smaller tweeter for a measurement speaker to measure microphones. They need 120dBSpl at 1kHz and measurements down to 16Hz. And I will also upgrade my main monitors in a similar setup.
That's the best speaker material availiable. Add Hypex or four audio electronics and someone who knows how to do the crossover and chassis (which is easier for in wall setups but different for hard frontwall oder soft soffit!) ... and you can configure the speaker you like to have.
But when starting such a project you first have to decide - wide radiation or controlled radiation (= wave guide or horn).
Btw - if you don't like B&W sound these Beryllium tweeters are very likely your thing.
Neumann - after what I experienced with the upgrade KH120 -> KH120ii I really see (and hear!) a big benefit of the digital versions! There will be an update of KH310 in the near future but KH420 will take them a while (at least what you find online on information).
I listened to KH120ii next to my main speakers which was very nice. But after calibration with MA-1 ... this was way to close. Of course you don't have the resolution of the midrange dome and the "relaxedness" of the Berylliumtweeters - but it was very transparent with a hint of "truth", I could totally mix and master with KH120ii and a woofer. (mixing also without woofer).
So in 2-3m distance a simple setup of KH120ii and KH150, calibrated with MA-1 (Atmos update should come anytime ... at least till next summer ;-)) and a dual bass array ... of course it's to cheap for your plans
but this is the perfect price/performance base for Atmos in my opinion.
You found my thread about SB Acoustic Woofers? ScanSpeak is also always great but costs a little more.
Go at LEAST for a single bass array! This is easy to integrate in a complete home cinema build. And has a lot of benefits. 6-8x SB34NRXL75-8 for example will do some serious impact ...
You could also think about bass shakers. I will install the Visaton units when my new couch arrives. The secret is the right filtering (they often have a strong resonance), low crossover and a LOW level! It's not a massage chair, it's just to feel these explosions even better. Had a testrun and it was really fun, expecially for gaming this should be cool.
