holdingpants01
- Joined
- Mar 18, 2023
- Messages
- 1,062
- Likes
- 1,812
20cm ceiling absorption in a 2,2m room? I hope the OP is not tall or doesn't have claustrophobia
That’s why I advised to build a SBA or DBA. That will eliminate all bass resonances. The ceiling absorption is only needed to get rid of those very short early reflectionsA 10-20cm ceiling absorber doesn't help with bass resonances at all!
You can't do magic - it's physics.20cm ceiling absorption in a 2,2m room? I hope the OP is not tall or doesn't have claustrophobia
That's what I'm saying, outside of physics there's also equally important visual side, this is suppose to be fun room and hanging 20cm of wool above the head for doubtful benefit is not fun. In the world where Dirac ART exist I probably wouldn't waste the space on any bass trapping, but that would've to be measured (science, physics)You can't do magic - it's physics.
A can-do attitude like yours surely helps. Is it enough, though?!You can't do magic - it's physics.
Have a look what 10cm of absorption do. I always say it's a minimum for music but for a serious room ... there is more or less nothing happening <100Hz.
You need more advanced absorber tech in such a room combined with some good speaker technology and room adaption ... not easy but it's doable.
This is too much text to parse, but briefly: I did quite a lot of rooms in my career, right now I'm sitting in a smallish 20m2 control room with treated ceiling, and mostly just ceiling because it's high enough to do it, so it doesn't feel like something is falling on my head and I like to see the walls (they're made from raw brick). It's an atmos setup BTW.I did rooms with 2,3-2,4m height - so I don't have to guess.You can't get a great live acoustic sound but a great controlled acoustic. And 20cm absorption at the ceiling is not "doubtful" - it totally transorms your room! Have you ever tried that? Entering such a room is already fun!
No practical experience here, I actually gave up on a similar room/idea. The theory/graphs were too discouraging: 10cm does ~nothing below 100Hz and 20cm ~nothing below 50Hz. Also, with 20cm of ceiling absorbtion in a 2.2m room, the sound may not matter much anymore - I probably won't like spending time in there.I did rooms with 2,3-2,4m height - so I don't have to guess.You can't get a great live acoustic sound but a great controlled acoustic. And 20cm absorption at the ceiling is not "doubtful" - it totally transorms your room! Have you ever tried that?
You can watch this guy: https://www.youtube.com/@AcousticsInsider he believes in as much absorption as possible in small rooms and provides measurements of finished rooms.No practical experience here, I actually gave up on a similar room/idea. The theory/graphs were too discouraging: 10cm does ~nothing below 100Hz and 20cm ~nothing below 50Hz. Also, with 20cm of ceiling absorbtion in a 2.2m room, the sound may not matter much anymore - I probably won't like spending time in there.
But that's just my view... and I only have theory and you say that you worked with similar rooms ... so there's that
Hope you guys find some solutions and wish you good luck!
P.S.
Progress reports and more info about similar rooms would be highly welcome. A few clear measurements may change my mind about those 'standard' 2.2 - 2.5m basements.
Thx for the youtube channel, looks interesting.You can watch this guy: https://www.youtube.com/@AcousticsInsider he believes in as much absorption as possible in small rooms and provides measurements of finished rooms.
To put things into the perspective, minimal legal height of a flat in my country is 2,5m. The 2,2m is the minimum limit in a places where a person can be only temporarily and doing only specific jobs, like a security booth. For living, learning or recreation it is 2,5m at minimum. Those are health related limits, I would seriously reconsider building anything there
I have the same dilemma!Hello,
next year I will be able to create my own home cinema/ music listening room in the basement, room is big (enough) and symmetrical. Around 27m2 / 290 square feet.
I really want to spend much time in this room, 50% of the use will be simply to listen to music. Its kind of unrelaxing to look on black walls and the white screen typically for a cinema room with projector so I decided to use a big OLED TV and create more of an relaxing area. Don't get me wrong, best audio/video quality is the goal here and the room will be acoustically planed/treated.
After calculating a little bit I found two possible high end setups for this room:
Genelec 8361A Front + Center
Genelec 8341A Rear
Genelec 8331A Atmos
or
KEF Blade One (or Two) Meta Front
KEF Reference 4 Meta Center
KEF R3 Meta Rear
KEF LS50 Meta Atmos
The KEF Setup is a bit more expensive, if you use amps like the TP RA3 this would also be possible.
I really don't know which setup is better on the paper, I know the Genelec Ones, they sound impressive. But I think, specially in Stereo, the KEF Blade can outperform the 8361A a little bit, the Uni-Q Driver offers a little bit lower distortion and the bass drivers are bigger which should also help. (for Stereo) The Blade has even a little bit better directivity plot the the Genelec. But I really dont know how well the Blade/Reference will mix with the R3, perhaps there will be a noticeable difference in sound between front and rear.
The Genelec Setup will have one big benefit, because all of the speakers are part of the One series, there will be nearly no sound difference between the channels. Not sure if the KEF HF/MF driver is the same in the Blade and the R3. And the 8331A for the ceiling should easily outperform the KEF LS50. (R3 is to big for the ceiling, room is only 2,2m/7,22ft high)
So what do you think, which setup is superior? Of course, I will listen to all of those speakers before buying. It will be impossible to hear all speakers as a surround setup so I need to decide with stereo speaker pairs.
Thanks!
Greetings from Germany,
Jan
do you have the ~same room/dimmensions too?I have the same dilemma!
How does an ls50 meta in the ceiling even work?Because ceiling speakers are all pretty bad. Even the Kef ones, which are better than average, are way way worse than an 8331A.
This isn't really that unusual -- all the newer high end studio setups I've seen use ceiling mounted speakers, not in-ceiling. Including the Genelec ones, even though Genelec makes in-ceiling speakers.
