Was the question you asked directly to 3eaudio? Have you dm'd them here @3eaudio ?Ok. Excuse me.
Hi! I wrote to the seller in the official 3Eaudio store. The seller sent a "recommendation from engineers" - to replace 2 capacitors. (look pics.1)Was the question you asked directly to 3eaudio? Have you dm'd them here @3eaudio ?
You can't measure them while they are in circuit - everything else connected to the circuit will influence the measurement.Hi! I wrote to the seller in the official 3Eaudio store. The seller sent a "recommendation from engineers" - to replace 2 capacitors. (look pics.1)
Before replacing these capacitors, I checked them on both boards. (look pics.2,3)
All 4 capacitors are serviceable. They have a capacity of 9.10mF - 9.90mF. It doesn't make sense to change them.
Here the advice was not just to change the capacitors. They are in good condition. But their capacity needs to be changed. The default capacity on the board is 10 uF. 3E advises replacing the capacitors with 1 uF capacity where the pop is. I have a similar problem when turning off on one channel on my stereo board. 3E gave me the same advice.The purpose of the replacement is to reduce the capacity.You can't measure them while they are in circuit - everything else connected to the circuit will influence the measurement.
What is the value shown on the capacitor body? (It's uF BTW, not mF).
We do not listen to sine sweeps or white noise.
Say that you're completely maxing out this Amp, playing well mastered music with even spectral distribution:
With 165W Peaks at <500Hz, you will only output ~8W at 5kHz, ~4W at 10kHz, and ~0.4W at 20kHz.
In this way, Amir's THD+N vs Power vs Frequency graphs can be a bit misleading.
100+ Watts at 5/10/20kHz is absolutely insane and does not represent real world usage.
A solution is to instantly disconnect the speaker connection immediately after the AC power line is turned off, or reset the TPA3255 and stop the amplifier from running.
This is very difficult. There is a simpler method (2), with one relay. In this case, the acoustic systems do not need to be disconnected.I put a relais in the + of the speaker and another switch. First amp on an then relais on, then relais off and amp of.
Have you actually tried this method and confirmed that it eliminates the popping noise?Н! How to get rid of the clicking sound in the speaker system when the module is turned off. There are two methods.
First.
You do not need to turn off the primary alternating voltage going to the power supply. This is exactly when this clicking sound occurs. This is due to the attenuation of the constant voltage, which is incorrectly perceived by the module circuit ...
You need to turn off the secondary constant voltage going from the power supply to the module. There should be no clicks.
Try it. If it does not help, I will tell you about the second method. The circuit is very simple. But you will need to use one simple relay, with one contact.
There is no mention of "PS_CTRL" in the data sheet for TI's TPA3255. There is no such pin in the pinout of the IC chip.Checked. Unfortunately, this method does not work. The capacitors on the module itself are discharged. After 0.5 sec - a click (pop noise).
Then the second method. It will work, because this is a function of the module itself.
There is a comb with contacts on the module.
If you close the contacts PS_CTRL and GND (there are two of them on the comb), the board will turn off. Open - it will turn on. The shutdown is instantaneous, without clicks (pop noise).
This way you can install a switch, and use it to turn the module on and off. It is better to close and open through a 50 Ohm resistor, but not necessary.
The downside of this method is that the power supply is always under voltage.
But you can improve it and turn off the primary voltage. After the switch, you need to install a 220 volt relay. And connect its normally closed contact between PS_CTRL and GND. Then, after applying 220 volts, PS_CTRL and GND will open, and the amplifier will turn on. And when removing 220 volts, PS_CTRL and GND will instantly close, and the amplifier will turn off without a click (pop noise).
The relay can be like this HJQ-13F-220VAC-1Z
I think "PS_CTRL" is probably an input created in the 3e audio amplifier circuit. Does it actually go into a sleep-like state?
It is important to know the function of "PS_CTRL". I have looked at the table in the 3e audio manual many times, but there is no detailed explanation.What does the technical data sheet of TPA3255 have to do with this?
We are talking about the 3E Audio module here. He has his own data sheet. See the screenshot.
Take a jumper and try it yourself. It works flawlessly, as I wrote above:
- If you close the contacts PS_CTRL and GND (there are two of them on the comb), the board will turn off. Open - it will turn on. The shutdown is instantaneous, without clicks (pop noise).
Amirm nice review again but I wish to know if would be possible to measure this module the graph of power vs distortion @ 2 ohm like you did in other amps like Hypex NilaiThis is a review and detailed measurements of the 3e Audio 480-1-29A, TPA3255 based class D amplifier module. It was sent to me by the company in a reference design for ease of testing:
The module is the PCB to the right and costs US 89.99 from company Aliexpress store. This is the mono version (I reviewed the stereo version earlier). The differentiation is pulling the required class D filter into the amplifier feedback loop (PFFB) and with it, essentially eliminate the effect of speaker load on frequency response. Low cost implementations lack this which can make the tonality somewhat variable. Other optimizations are done to extract better performance out of the TI TPA3255 class D amplifier module.
When swapping the stereo module for mono above, I was impressed by the hefty machined aluminum heat coupler. It is quite substantial and spreads the heat nicely to large area of the case bottom.
The included power supply in this sample is MORNSUN LOF550-20B48-C. Specification is 48volts at 6.5 amps with air cooling and 11.5 amps with forced air. Latter allows more than 550 watts to be provided to the amplifier.
3e Audio 480-1-29A Amplifier Measurements
The initial set of measurements match the stereo version so I will quickly go over them:
We get more power:
We had 206 watts in stereo. Same improvement with 8 ohm load:
Stereo version produced 92 watts.
Interesting to see the transfer function change some in this version:
Cleaner than mono at first but then worse at higher frequencies. Here is the stereo version again:
I captured the switching frequency and was impressed by how low its level was, and how high the frequency was:
Amplifier Reactive Load Test
This is one robust amplifier, essentially not caring about the load down to impressive 2 ohms!
You get nearly 600 watts here!Note that the test only keeps the amp at these power levels for short period of time so this is not "continuous" amount of power in the pure sense of that term.
I don't know what to be more impressed by: the TI TPA3255 or 3e Audio's engineering skills. This is an incredibly well performing at this price level. Of course you have to account for adding a capable power supply and case to get these numbers but still, one can't help but be impressed.
I am happy to recommend the 3e Audio 480-1-29A, class D Amplifier.
Manufacturer Specifications Amp Module:
- < 85uV Output Noise (AES17,A-weighted)
- 480W @ 1% THD+N, 1kHz, 2Ω
- 600W @ 10% THD+N, 1kHz, 2Ω
- 111dBA dynamic range
- THD+N < 0.01%, 0.3W – 300W, 3Ω
- 90% Efficient Class-D Operation (4 Ω)
- Fully differential layout design for lowest noise and distortion
- Very Compact size(105mm*90mm*38.5mm – L*W*H)
- Additional power ON/OFF reset circuit for Pop noise suppression
- BTL configuration only for best audio performance
- AUX Power Supply Output(12V/0.2A) for DSP Pre Amplifier
- Single supply voltage range 24V~51V(UVP:24V)
No, 80C is well within the temperature rating of the resistors, as well as the temperature rating of the PCB material itself.I tried to measure one of them and got a temperature of 80°C. Should I worry about it?
1,5Ohm is only the DC resistance. The impedance while listening music is something else.I use the 480-1-29A to drive a 1.5-ohm sub driver. It works pretty well, even though 3e has not rated this board for such a low load. The metal plate mounted on the case got only slightly warm. However, I worry about those PBTL resistors; they are really hot and not cooled by anything. I tried to measure one of them and got a temperature of 80°C. Should I worry about it?
