Hi,
I’m just joint this community because I having this amp for about 1.5 months and have using it daily as a bedroom system. Very interesting product as it is.
Yes, I did notice the clipping on it even use the 3.5mm output from the MacBook to feed it. Moreover, the line level of external DAC will make this amp clipped. At DAC output at 0db, I can only move the volume up only 3 LED dots and it’s become pretty loud. Luckily, my DAC also has the pre mode built in it, I think at about -6 to -8 dB was ok for this amp. However, it’s a bit annoying that I have to attenuated the line level signal before amplified it. And, I don’t know where is the best spot to do it. (Can’t find where is the exact 1V. point.)
Fortunately we have the maker here, 3e. So, I’ll waiting for the solid solution such as changing the resisters or others. And looking for the “normal user” guideline to access the DSP and play around with it.(I have read some guidelines on this thread but still not clearly understand.)
Sorry for my eng as it’s not my first language
Best Regards,
