Not better than 96/24 (even considering 4db)
Noted, thanks for checking.
Best is feeding DSD256, as HQP developer has also stated in his measurements
I will link to his measurements when I can find them
Thanks WolfX, I just got the spring 2 lv2 also for about a week and a half and really satisfied, but a bit disappointed by the channel mismatch on distortion. will you have any update on that after the unit have been warmed up (always on and only mute used as factory suggest) and burnt in for a week or so?
I will try
Can you also retry HQP PCM1536 kHz
But this time set HQP output to 20 bits? As per screenshot from Miska I shared a few posts above:
https://www.audiosciencereview.com/...-of-holo-audio-spring-2-lv2.10678/post-296982
Also choose Gauss1 dither and poly-sinc-ext2 filter
It's set, but in the settings panel you will have no output!I don’t see output bits selected to 20 bits though?
Miska himself said anything higher will result in distortion (with Spring2)
It looks when oversampling externally the channel difference is lower?
As I know of the spring 2 used a different ladder set for ssd and pcm, so for dsd I would think it maybe manufacture defect, but the pcm nos showing quite obvious channel difference while os pcm dont is more of a surpriseAnd with DSD256, there is no significant channel difference at all
https://www.audiosciencereview.com/...-of-holo-audio-spring-2-lv2.10678/post-296723
No, I mean since they use different ladder for pcm and dsd, so it makes sense the dsd is more balanced than the other as the ladder manufacture tolerance should be random within their own qc spec. So the dsd ladder shows less variation than the pcm ladder or vice versa makes sense.Do you mean it is a defect that SINAD is 112dB for both channels , with DSD256?
@WolfX-700
One final test if you can.
Any difference between DSD128 and DSD256 measurements?
HQP developer has done testing with up to DSD1024 (which his software and Spring2 USB input both supports) but he said Spring2 measurement “sweet spot” is DSD256.
I suppose it would have to since DSD is 1-bit at higher speed it presumably doesn't or couldn't use the ladder which is needed to decode PCMAs I know of the spring 2 used a different ladder set for ssd and pcm, so for dsd I would think it maybe manufacture defect, but the pcm nos showing quite obvious channel difference while os pcm dont is more of a surprise
Yea, this is why I am tempted to know if it's WolfX's unit have a worse matching PCM ladder or it really is the run in or warm up thingI suppose it would have to since DSD is 1-bit at higher speed it presumably doesn't or couldn't use the ladder which is needed to decode PCM
