I was waiting for this test
WolfX-700.. Thank you
Congratulations
JohnYang1997 on your contribution to the design.
A question if you don't mind. Whether the headphone output is balanced or not, I would be interested to know if the processing of the two channels is totally independent in this output.
I currently have an SP200, but maybe I cheer up with the A90 to combine it with the D90 that I already have. It would be your perfect partner.
Just as a comment. I have seen so many times in good level equipment "the need" for the power supplies to be external or separated / isolated from the rest of the electronics, transformer vibrations, radiated field etc. I was struck by the excellent technical characteristics of the D90 with an internal power supply included in such a small space, transformer welded to the same motherboard, near the electronics, etc. With the A90 I am even more surprised by being SMPS. I guess the new generations of low noise voltage regulators must have a good responsibility in that.
¿To what extent does it limit or not, having an internal power supply? That is, could you have any advantage in benefits if these power supplies were outsourced?
Thank you.
