Whilst all that is true I'd assumed we were talking about professional monitoring equipment, not PA systems which are a whole different ballgame.
- Noise has never been a primary focus for professional sound reinforcement gear. Noise is acutely important and audible in a domestic environment. That noise can be mechanical (transformers/fans etc) or electrical (hiss/hums/buzzes etc).
- Wide and flat frequency response is not a priority for "pro" gear. The last thing they want is instability so BW is often tamed.
- Harmonic distortion is hardly a driver in power amplification in professional gear- it's all about sheer wattage.
- Size and weight is not an issue in home high fidelity equipment (for most audiophiles)- it is a major consideration for travelling or pro installs.
- Susceptibility to transport/impact damage between home HiFi and Pro gear is completely different and expectations for same are too.
RME have remotes at least the components which straddle the pro/domestic line.Another reason, pro gear has many inputs and 8 or more channels. Consumer audio gear has no need or use for it so a consumer wonders, what would I do with that? I'm paying for something for which I don't have any need.
Can you name/show us, one just 1, exemple of:Home and Pro audio equipment have huge price ranges. So it can't really be compared. The assumption that audiophile gear is more expensive than the Pro is to my opinion not valid. Good pro stuff is as far I looked at the price tags more expensive, but built for 24/7 usage without problems.
Although not $500k, professional main monitors can be very expensive, e.g. https://www.rspeaudio.com/pmc-loudspeakers-qb1-xbd-a-main-monitor-with-xbd-cabinet-pairCan you name/show us, one just 1, exemple of:
a $500,000/pair pro speaker?
$350,000 pro amplifier?
$100,000, 8 feet, yes EIGHT feet Pro speaker cable?
$100,000 Pro DAC?
The list could go on
Peace.
My point wasn't that some Pro items were not very expensive simply, that similar (HEA) audiophile wares are vastly more expensive.Although not $500k, professional main monitors can be very expensive, e.g. https://www.rspeaudio.com/pmc-loudspeakers-qb1-xbd-a-main-monitor-with-xbd-cabinet-pair
On the other hand these monitoring equipment operate in often $100k (or much more) treated rooms and they rely very little to EQ because of that.Whilst all that is true I'd assumed we were talking about professional monitoring equipment, not PA systems which are a whole different ballgame.
Subjectivism in the pro world is subtly different. For the engineers operating the mixing panel etc. there's a general acceptance that some cable is better than other cable, but the choice is often on noise, microphony, robustness, flexibility, rather than "veils being lifted".M point wasn't that there weren't expensive pro items. Simply that audiophile wares are vastly more expensive.
OTOH, one must realize that subjectivism is as widespread in Pro corners as it is in the "audiophile" sector. As such it creates a fertile environment for overpriced products, even BS products... I have this nagging feeling: perhaps such as this very PMC exemple?... Audio Subjectivism and prejudice...
Peace.
