Yes, I use the DF target curve to correct the headphone response.
Let me give a simple example with a diagram.
Let’s assume that when you wear a certain pair of headphones, you get the green response curve. Simply inverting that curve gives you the blue one. In doing so, you’ve effectively equalized the headphone’s own response, right?
And the equalized response must be in place before you can hear your binaural room response.
Let’s walk through another simple example. This time, imagine the response curve is completely bizarre.
This response curve might look like a bizarre, jellyfish-like shape, but it doesn’t matter what the target is—our only goal is to equalize that response.
So, would the headphone responses in the two examples now be the same?
Yes—ideally they’d be virtually identical. If you’ve equalized them properly, the worn IEM/headphone response is flattened, so the curves match almost exactly (aside from any device quirks or leaks from an imperfect fit). At that point, they’re just acting as playback devices for your binaural room impulses.
Can you tell me more about how you would personally equalize to make the headphones "disappear"?
There are lots of different approaches. Some people prefer David Griesinger’s two-tone method, though I personally found it awkward.
What I usually do is just tweak by ear: I listen to the inverted headphone (or IEM) response without any BRIR to establish a basic EQ curve. Then, with the BRIR applied, I fine-tune while listening to music, pink noise, and sine sweeps. Or When I’m feeling lazy, I just throw on the BRIR plus the partially corrected headphone response and listen to music right away. I know how things should sound to me and what a flat response feels like—my brain and body both recognize it as the perfect reference—so I can immediately hear anything that’s off. That’s why sometimes I skip all the complex steps and just EQ it on the spot.
Of course, if you record the headphone response with an in-ear mic, most of it shows up in your HPCF—but some elements get left out (like certain eardrum reflections or your personal hearing characteristics), and that also depends on how you make the measurements.
Or you could extract the consistent differences between standard measurement rigs (GRAS, 5128, etc.) and your own actual HRTF, then use that as a sort of calibration curve. I’ve tried various methods for others, and since the results were almost always the same, I personally prefer to just listen and tweak by ear. It’s best to find the method that feels most comfortable to you.
(And every so often, some users worry that applying too much EQ during the BRIR process will introduce phase distortion. But the fact is, if you haven’t applied a proper, individualized HPCF, you’re already listening to a distorted response. No matter how dramatic your EQ moves are (–10 dB, +10 dB, etc.), if the result matches what you actually hear in reality, you’re not adding distortion—you’re removing it.)
I’m doing my best to understand your situation, but it’s hard to get a clear picture from such a brief message. If you could share details about your room response and headphone response, what software and hardware you’re using, how you measured everything, and so on, we’d be much better able to grasp your concerns.
Also, writing this has made me curious about your situation—seeing that you’re calibrating your headphone response to a DF target.
1. Are you using the binaural room response you recorded at your ears together with your headphone response to perform the virtualization?
2. Or Are you trying to take a response that was made for another user or a dummy head (even though the headphones are the same model) and adjust it to better match what you hear?
3. Or Are you simply listening to a standard binaural recording or video through your headphones, rather than using a personalized virtualization captured from your own ears?
