19 square feet of space in pursuit of sound reproduction listening distance of 2.5 meters with 150 + 750(2.1) good or f206 good it?1) The Revel is passive; no DSP. The Neumann uses DSP.
2) The Revel is floorstanding. Manufacturer assumes that the speaker will be used in a larger environment, and that there will be boundary reinforcement. The Neumann is targeted for the nearfield, where such reinforcement is greatly reduced or nonexistent.
3) The Revel is designed to produce high SPLs because of use position. The Neumann, less so, again because of use position. Therefore, the Neumann can be equalized to a greater degree, achieving flatter and deeper response at the cost of output.
Jim
ah ....... and about the measurements?
Jim
Exclude dsp and still have the same problemA passive speaker Revel F206 and a monitor studio Neumann KH150 (amp+dsp) do not have the same purpose.
If you want to give justice to the F206 in this comparaison, place an amp+dsp driving the Revel.
A room correction with bass boost will do a similar job to what is made inside the KH150.
A modern AVR is able to do that.
The same size speaker speakers, I feel that the active box than the passive box of low-frequency dive to deep, I feel that it should be and active box of high-frequency and low-frequency independent amplifier to push the relationship
词
500cmx400cm
Now I am considering to buy 310 or 150 + 750, the forum said 310 clarity is not as good as 150 now I am very tornThank you.
4 meters x 5 meters is 13x16.5 feet, with a listening position 8 feet (2.5 meters) away. That room is large enough for the Revel. The ideal listening distance for the Neumann is less than 8 feet (2.5 meters) away.
Jim
Thank you.
Jim
