Count Arthur
- Joined
- Jan 10, 2020
- Messages
- 3,162
- Likes
- 8,299
My twopence.
Anecdotally, on a previous PC, I had an issue with the DAC connected to the PC where I would hear noise, a sort of high pitched whine, when I moved the mouse. Connecting the DAC to a different port on a USB PCIE expansion board fixed the issue.
The USB ports on the outside of a PC case are not all connected and implemented the same way within the PC. Ports on the front of the case will be connected via a header cable, whereas those on the back plate, are connected directly to the motherboard - a possible source of noise?
On the motherboard itself, different ports are connected in different ways to the CPU, some directly, some via the chipset.
Exactly how this is implemented, varies with different CPU and chipset brands and models:
All this is to say, that not all the USB ports in a PC are completely identical. What the specific issue is, I couldn't say, but given that some ports are connected/implemented in a different way suggest that there is a mechanism for there to be issues with some ports and not others.
