It is the output from the dac which is important.
Can you hear any noise? Say during silence between tracks with the volume up? If you can is it different between the USB ports?Interference in the form of noise,
It is noise only (not harmonics). Most likely a ground noise issue (even when not used for power, the ground is still connected), and if so different cable impedance in the ground connection could result in a difference.So, no explanation, great... This is especially interesting because in this test USB cables were not used for power, they were used for data transfer only. Doesn't make sense.
Since we're talking about measurements, as the "Thoughts and Conclusions" section of this webpage mentioned, how these noise levels affect DAC output hasn't been measured.And some here claim that there can be no difference between different USB ports. Here is proof that there is a difference! With measurements. https://archimago.blogspot.com/2018/05/measurements-computer-usb-5v-power.html#more
www.audiosciencereview.com
Those tests lack any real information.And some here claim that there can be no difference between different USB ports. Here is proof that there is a difference! With measurements. https://archimago.blogspot.com/2018/05/measurements-computer-usb-5v-power.html#more
everyone is free to fake measurements.it is even possible to 'fake' such proof (measurements).
People are free to do a lot of counter-productive things, which are not worth doing.everyone is free to fake measurements.
In short, everyone around is lying and it is impossible to prove anything to anyone.everyone is free to fake measurements.
What exactly are you striving to prove here? If you think different USB ports sound differently, then it's your right and your experience, good for you. Others may disagree with you, so don't waste your time.In short, everyone around is lying and it is impossible to prove anything to anyone.
Because the theory of the operation of digital circuitry denotes that USB ports do not sound different when operating properly.In short, everyone around is lying and it is impossible to prove anything to anyone.
True, but missing the point entirely - this variation in power line noise is well known and expected. A competently designed USB DAC has sufficient internal regulation to deal with this, so its output won't be affected by this variation in noise. Refer back to post #55 for links to Archimago's test demonstrating this for a well designed DAC, and for the Modi 2 test where it wasn't done properly.And some here claim that there can be no difference between different USB ports. Here is proof that there is a difference! With measurements. https://archimago.blogspot.com/2018/05/measurements-computer-usb-5v-power.html#more
Ok.What exactly are you striving to prove here? If you think different USB ports sound differently, then it's your right and your experience, good for you. Others may disagree with you, so don't waste your time.
I don't think we need to feed this troll and explain them the obvious basics a thousandth time over. It's obvious they are just fooling around here out of boredom. Let's ignore them. All their contribution here is making outrageous claims and trying to get attention.True, but missing the point entirely - this variation in power line noise is well known and expected. A competently designed USB DAC has sufficient internal regulation to deal with this, so its output won't be affected by this variation in noise. Refer back to post #55 for links to Archimago's test demonstrating this for a well designed DAC, and for the Modi 2 test where it wasn't done properly.
'when operating properly' has a number of assumptions built in. I covered some in post #55 - feel free to add any I missed. Back in post #13 OP's description of noise seems like a ground noise issue which may genuinely be different between ports. Insufficient 5V line regulation/filtering is another possibility, although less common.Because the theory of the operation of digital circuitry denotes that USB ports do not sound different when operating properly.
Definitely! What other choice you have?The one that I like the sound from more?
