BeeInMyHead
- Joined
- Apr 20, 2025
- Messages
- 7
- Likes
- 6
Current Audio Chain (source to destination):
PC -> USB to USB-C Adapter -> USB-C to Micro-USB cable (included) -> Tempotec Sonata HD Pro DAC dongle
-> Long audio cable -> S.M.S.L SP200 Amp
-> Long audio cable -> HIFIMAN Sundara
Issue:
I experience significant electrical noise/interference under the following conditions:
The interference rises by magnitudes whenever my GPU ramps up (GPU has coil whine).
Observations:
Solutions?:
EDIT: Actually now that I think of it maybe it isn't the distance and really a grounding issue? Because the monitor has its own power supply. So maybe that somehow impacts things? Still unsure though.
EDIT2: Issue is the same if PC and SMSL Amp have different power outlets compared to putting them onto the same strip.
Issue:
- Plugging USB adapter into motherboard USB ports (high severity)
- Plugging USB adapter into front panel USB ports on the case (high severity)
- Directly connecting the amp via audio cable to motherboard/case audio jacks without DAC (extremely high severity)
- Connecting amp directly to monitor's audio out without DAC dongle (low-medium severity)
Observations:
- The issue significantly improves (almost disappears) when connecting my amp via the monitor's audio output, hinting that physical distance or isolation from the PC helps.
- Using the external DAC dongle reduces the issue noticeably compared to directly using motherboard audio output.
- Connecting the amp through the DAC dongle to my laptop or smartphone results in no interference. AMP and DAC do their job well in other scenarios.
Solutions?:
- Distance of DAC conversion?: Perhaps a longer USB cable in between the DAC and the USB adapter connected to the motherboard might help. Unfortunately I can't plug the DAC dongle into my monitor to test this slightly.
- Ground loop or improper grounding/shielding: I've considered grounding or shielding but everyone online seems to have different solutions for this and there don't seem to be easy answers..
- DAC replacement: external desktop DAC instead of a dongle might fix the issue. But I feel like that is just solution No.1 wrapped up nicely.
- Balanced cable?: I don't know if this will fix things but maybe? But I wonder if this will only mask the issue or if it will truly fix it perfectly.
