With solid gold feet it would actually appreciate in value, unlike the typical audiophile rack that drops 60% in value the second they buy it. So you might be onto something there.The only worthy hifi rack has the feet made of solid gold and the shelves made of white statuario marbel. It makes the sound absolutely precious!
I'm at the point in my life where I don't want my media system to look like something that would be more at home on the stage of a dive bar than my living room. So for me, media furniture is not about grasping for some final increment of sonic transparency, but rather about creating a "put together" look to my living space. So for me something that looks like this:
is worth the money.
Heresy!Sinatra will sound better at least
Actually I was looking at some system pictures on another forum and someone was using a modified drinks trolley (or possibly hostess trolley) as a rack.
Regardless, audiophile anti-vibration products are touted as improving all component performance including computers, amplifiers, power supplies and other devices with no piezo-electric components.
Good stuff Mart68,Thing is, with a turntable we are talking about a device that is designed to pick up vibrations. Not true of any other hi-fi component.
I've also had that issue with bouncy floors, so I now have solid floor. Better for speakers too.
Dieter Rams (Braun) is a legend among industrial designers. Jonathan Ivy says he was inspired by him. And you can spot that.There are super cool audio racks. For example...
Braun Atelier series:
Pioneer Spec:
Aiwa micro component:
Nakamichi:
What test?If only there were a way to test it....
www.audiosciencereview.com
This only really works with a lot of weight and strong damping at the transition from floor to rack. Alternatively, directly on the device, but neither is a good idea.Did a little test,just lightly tapping rhythmically my interface while measuring:
left alone
messing with it
It seems there is some truth to the vibration thing but I don't know what kind of rack would solve it.
I think that what saves this little plastic thing I tested (E-MU 0204) from being like that constantly is its little soft feet (still soft after 20 years)This only really works with a lot of weight and strong damping at the transition from floor to rack. Alternatively, directly on the device, but neither is a good idea.
I would move if there were such massive problems, as such vibrations have a very negative effect on people.
Still not cheap even if usedUnfortunately it is no longer manufactured.
I would actually be interested in that too.I think that what saves this little plastic thing I tested (E-MU 0204) from being like that constantly is its little soft feet (still soft after 20 years)
The effect is not visible at all when tapping right next to it.
Next test I'll do is to put it on the side of a speaker while playing loud something that has impact.
We'll see.
Skipping the rubber feet?I would actually be interested in that too.
Just put 3 or 4 M8 or M6 nuts directly under the device.
What happens then if you knock next to it and directly on it?
You've missed an important line, he wants €400-600 per rack.
