4buFahad
What is the best HD 58X sound card?
Knowing that I have a DROP O2 + SDAC DAC/AMP and I want to upgrade, what would you recommend me to upgrade to
Do you recommend a separate AMP DAC?
translate.google.com :"(
Doodski
The EVGA NU Audio Pro @ USD~$300.00 or can get the lower model for $200.00
4buFahad
4buFahad
Sorry I mean amplifier, not a sound card
Doodski
I suggest you change the title to needing a amp or a AIO DAC/AMP. Or start a new thread.
AnalogSteph
.de
What features are you missing from your existing setup? Or does it not work properly or something?
Otherwise I don't see a need to upgrade at all. It's not going to sound any better. A HD58X is not a very demanding headphone, and the SDAC seems to be fine.
