ernestcarl
Even if you use a NAS, better make sure to have an offline-offsite backup in case of a catastrophic disaster e.g. lightning storm or fire. My offline backup is updated yearly.
I hate to say it but your life would be massively improved by forgetting locally stored music and getting lossless streaming. The cost of an 8-10TB NAS would pay for months of streaming fees, plus you get access to any new music.
I had the epiphany about 2 years ago. Do a trial tidal/ qobuz , see how you get on. Both should go lossless via airplay to the Yamaha.
EDIT- points raised below all valid- I'm just suggesting you trial streaming for a month or so before committing to local infrastructure / storage. Nothing ventured , nothing gained. For me it was brilliant- as I was struggling with the local storage options and buying FLAC files for new music- going forwards with streaming for new music was a no brainer. As it turned out, combining Tidal with Roon and keeping the few files I had not on Tidal and integrating streaming and local was the ideal solution,
Are you saying just dont worry about my own music, get Tidal and whenever I want to listen to something type it in because all my music is probably already on Tidal and I can just listen to it there?
What is the sound quality through Tital? Is it comparable to something like a SACD?
No, that is not the task of a NAS.
Most of the time we use our media player to manage our collection.
Yes, thats what I am saying (although as others have pointed out, no service will have 100% or your existing music, so you would either accept that or workaround)
You didnt say what format/ quality your files were in - I assumed ripped CDs or similar.
Tidal, Qobuz and Amazon HD offer lossless (cd quality) and above (up to 24/192 PCM) but no, to the best of my knowledge no service streams DSD so if thats what you are after, scrap that idea!
None.How much 24/192 is there on Tidal?
How much 24/192 is there on Tidal? If you have the High Res subscription is all of Tital streamed at 24/192 or just a small selection of music? Any idea if theres a noticeable difference between Tidal high res 24/192 vs listening to a sacd of the same recording?
None.
(following on from previous post)
I'm not trying to get you to do anymore than try streaming. Couldn't care less which you pick if any. I use tidal because it's (mostly) lossless and has a multi user family plan. I'd actually rather use qobuz but they currently have no family plan.
Amazon HD doesn't integrate with roon so that's out for me (but it's the cheapest)
There may be others to try. They all offer a reduced /no cost trial period which is easy to cancel. Your phone and the yamaha should both work with the relevant provider app or other 3rd party apps
No idea how good any of it sounds compared to dsd/sacd. Never owned or streamed any. If that is what you are after, current streaming offers aren't for you.
RAID is not a substitute for backups. Primarily, RAID provides high availability since it enables drives to be replaced with zero downtime. This should ideally be done before the drive becomes non-functional, typically when the number of spare sectors drops below some threshold. While sudden failure of a one drive (or more, depending on the RAID configuration) is tolerated, other failure modes are not recoverable. Examples include accidentally deleting/overwriting files and simultaneous failure of multiple drives due to a power surge or disaster (fire, flooding).RAID 1 provides pretty good self-backup for the NAS
I do it monthly.Even if you use a NAS, better make sure to have an offline-offsite backup in case of a catastrophic disaster e.g. lightning storm or fire. My offline backup is updated yearly.
