I just ran through the setup of the Dirac 3 trial tonight and it was an unmitigated nightmare. I'm a Product Manager by trade who's been developing consumer having software for 15 years and the entire experience left me shaking mad trying to get it to work.
After installing everything I was greeted with a message that I didn't have a license and was prompted by a non direct link to acquire one. After getting that, I still couldn't figure out how to get the license to connect to the software. After a long while of troubleshooting I saw in the bottom left hand corner I was auto signed in to an old account from when I joined the Dirac 2 beta that never worked for me either. Ok, fine. Probably not a primary use case.
I go into the calibration section and I have no idea what do do. No call to action, so I click on everything - nothing happens. I.play the noise tone and nothing. I decide to turn it up, and once it's blaring loud I see a tiny little black line that represents the meter. Ok. It doesn't tell me when to stop so I turn it up as loud as I can handle, which is only halfway in the blue. Fine.
I run the tests and the first one is so loud it's painful. I look at the dots on the screen for where to place the mic and it just says Next. So, I guess at where it wants me to put it. Once I'm all done I accidently mouse over one of the dots and it tells me the position - that would have been useful info to have. Much to my surprise the entire thing is backwards. The right most dot represents "far left". They did the entire thing from the perspective of the person sitting in the chair. Who on earth would do that intuitively?
I view the filter page and again, just a total guess as to what I'm supposed to be doing here. I dumble my way through it and export the filter which loads into the processor without issue. Yay!
This is where the nightmare begins...
I soon realize that the filter isn't having any effect. I'm a long time user of EAPO, so I try a bunch of known troubleshooting. I restart the computer, uninstall all the software, reinstall - nothing. I just can't get the virtual device to show up. I reread the docs 5 times, scour the net for clues, try to contact support only to be respected to the same knowledge base and quick start guide and I'm ready to throw my keyboard through the television.
Finally I find a doc that talks about using vsthost and voicemeeter. Voicemeeter is a total dealbreaker because it massively degrades sound quality when it decides to and chews through processor cycles, but I figure I can use vb cable. I set up the VST host they recommend - the first one deadends on the link from the docs and come to find out you either need to subscribe to them or build not from a github repo. More chores for a $500 app.
I find a different free one they recommend and the instructions are wrong in several places. I get it all setup to find that in order to work, the disc processor has to run inside this janky vst app that seems like it's from 1994. If I close it Dirac stops. Whatever.
How does it sound? Hard to say. I was so pissed off by now that any impartiality went out the window. That said, the dialogue resonances I was trying to correct were still audible, so it's not even like it paid off in the end.
Very long story short - I wouldn't use this for free in its current incarnation, let alone shell out $500 to do some personal home theater EQ. I'll stick with REW until they figure out how to make good a good experience with results worth the investment.
I would like to know if a skillful usage of REW&RePhase will show similar results. Or Acourate?After using the 'focused imaging' arrangement on Dirac 3.0 for a week or so, I'm very very impressed by how well it performs. My bass response sounds better than anything I could achieve (or have achieved) myself manually (or anyone without a proper education on acoustics for that matter). Also, apparently there is something called a sound stage that I didn't have before.
I really thought it was expectation bias, but I can ABX the Dirac filters (MiniDSP device) and this thing is really doing God's work on my system.
I mean it won't fix any speakers that are inherently flawed, but I feel it did a good job separating the effect of the room and the response of my speakers, even though it took like only 10 measurements in total.
It was honestly so good, that I firmly believe now that unless you're a therapist or doing a job that only a human can do, a robot will replace your job eventually.
I feel like among the things that are talked about in this forum, these sort of solutions (that arguably has the most impact) are rarely talked about or recommended, and it's mostly about buying the 'best gear' or having the 'prettiest toy' with very little evidence (excluding speakers and headphones) on how audible that investment will be.
So feel free to share your experiences with Dirac and this thread, perhaps we can inspire other people to invest in it.
No, so I'll probably waiting until forever. Problem is that Dirac license is per channel, so a 16 channel processor is super expensive with Dirac. Don't want to pay for 5-10 channels of Dirac I wont use.They mentioned that they will release one?
After about five years of using Dirac Live occasionally, I stopped using it as I felt it will make the sound artificial and less sounding like real music. You can't put some nonlinear speakers in an acoustically horrible room and expect to correct everything with Dirac. I prefer to control early reflections passively (using panels).
An absorber doesn't remove the early reflections, it only reduces its volume, they also does not have flat absorption curves so the volume reductions are not consistent over the entire frequency range. As result, your off-axis response is getting colored / less flat.
For me knowing the Spinorama of your speakers + adjusting Dirac accordingly gives you an astounding result.
but no speaker will reflect all frequencies at the same level from directivity point of view.
For my taste and according to my experience (own and use both Acourate and REW since many years and have tried also a Dirac 2 and 3 test versions) they can give similar good sounding results as I personally anyway prefer minimal corrections.I would like to know if a skillful usage of REW&RePhase will show similar results. Or Acourate?
Dirac is good stuff, and one of the few automated room correction systems that actually knows what it's doing. But I feel like we talk about it all the time! Maybe that's just me.
Clicking on the question mark on the top left will give you information on what to do on each step of the process.
I have a feeling that you man-handled the process because of your background and experience and didn’t pay much attention to things.
Dirac Live only generates the filters, they provide another software to apply them.
Is it possible that the configuration issues were a perfect storm on my machine? Sure.Ever wonder if it’s just you?
The sound setup, reverse orientation of the measurements, lack of filter information etc. All appears to be part of the core feature set, unless they created a worse version of what everyone else has just for me.
Well we had opposite experiences - I find it easy and intuitive. Particularly compared with other apps. Key thing though, it works.
