BullBuchanan
- Joined
- Mar 27, 2019
- Messages
- 114
- Likes
- 27
I agree the Dirac Live software is clunky and unclear. When I first started using it (the webpage was a little different) I couldn't for the life of me figure out WHAT to download. I'm running it on a Mac and host it with SoundSource (which is excellent btw), but there is a bug in DL3 where it won't play sound unless you already have sound playing before you run DL3. So I have a 30min noise file I play in Quicktime, then load DL3 and then it works for running a measurement/calibration. From there its pretty smooth sailing and the plugin works perfectly hosted in SoundSource from there on out.
Software hassle aside, it is an absolute GAME. CHANGER. I want to yell from the rooftops to everyone wasting their time and money on speakers with no correction, use this! I've played around with REW a good bit, demoed Sonarworks and IK ARC3, but none of them work as well as DL. DL just sounds "right". I use the Olive-Tool target curve, load it up, and BAM, perfection. I correct full range as I find it tightens up the image as well.
BullBuchanan, you can correct with a subwoofer. I do this by using an REW RTA with periodic pink noise to roughy dial in the sub level and xover point. Then I run the DL calibration as normal. The subwoofer plays along with each left and right channel and it fixes everything up nicely. You don't have to do the REW RTA step, but that'll take some of the heavy lifting off of DL.
Yea, I just did the EQ manually through REW using the method you described with a moving mic. Granted, maybe you can get slightly better EQ results with Dirac, and they may be doing other things under the hood with timing and phase that you aren't getting with REW, but it's hard to say since they hide what's actually going on. My results were pretty spectacular using that method, and honestly seemed better than my one pass with Dirac - but part of that (maybe a large part) could be that I did my setup with "Subwoofer Plus" instead of just the mains via DL.
I appreciate that someday DL may offer a low-hassle solution for folks that want plug and play, but right now it's not really the case and they're charging a massive premium for it. Considering you get Audyssey XT32 included with your $400 receiver, I'm just not sure that as of today their value prop is that much stronger to warrant all the out of pocket + the hassle.
I hope that they can convert me someday though, because I'd like a global solution not bound to a box.
