25.5What is the gain on that?
I received a 4-channel VTV amp w/ the NC502MP modules and no 12v trigger this past week. The amplifier runs perfectly and is flawless in operation. However as some mentioned here there’s a loud pop when my unit is powering down.
Is the loud noise at all damaging to speakers? Anyway to fix it without having to install or modify anything? TIA.
Ok, I’ll try that. Do you know if this loud crack is harmful for speakers? Any way to take care of the DC offset issue if that’s the case? I appreciate it.Some hypex amps have a turn off thump. If you have a loud crack, start by disconnecting your preamp from it and power cycling to see if it is better. If it is, you have an upstream component generating DC offset.
I wish there was some way to definitively answer your question but we can't determine how loud is "loud"?Is the loud noise at all damaging to speakers?
Not that I can think of, have you talked to the manufacturer?Anyway to fix it without having to install or modify anything? TIA.
The popping sound upon amp shutoff is definitely louder than normal, maybe 80dB loud?, rather than just a slight pop. But chatting with the manufacturer, who was kind enough to answer product questions on a weekend btw, the pop while annoying is normal. He says efficient speakers, like I use, will tend to accentuate the popping sound more. I can live with that if it doesn’t mean anything getting damaged.I wish there was some way to answer your question but we can't determine how loud is "loud"?
In the vast majority of cases I would say no, don't worry about it.
But obviously at some point of "loud", a speaker could be damaged.
My best guess is, if it doesn't rattle dishes in the kitchen, your probably OK
but but but but?
Hypex ncore measures way better than Pascal.I am Debating on getting either:
Buckeyes Hypex NC502MP Amplifier, 4-channel
Or
VTV PASCAL L-PRO2S Four Channel Amplifier 4X800W
I can afford the $250 price difference.
Is there a reason to get one over the other ??
This would be to just power my LCR speakers in my HT.
LR Speakers: Emotiva B1+
Center: Emotiva C2+
AVR: Integra DRX 3.4
Please don't cross post questions in multiple threads.I am Debating on getting either:
I like the use of the wood panels, very handsome.I use pro-ject for box ds2 digital as a preamplifier
