- Joined
- Sep 4, 2019
- Messages
- 1,175
- Likes
- 2,341
For the past couple of years I have used a Parasound Zamp .v3 for my desktop system and enjoyed it. While I have from time to time thought about upgrading it, its size and cool running have kept it in place. Then Amir had to go do his darn test of it. That was enough for me to start poking at new amps. For me it quickly came down to the Schiit Vidar or giving a Class D amp a try. The Vidar was ruled out as being just a bit too large and power hungry (I tend to forget to shut off my amp and the Vidar draws a fair amount of energy at idle). I then started looking at Class D and based on the reviews, Hypex Ncore rose to the top for in the reasonable price stereo camp.
After researching, it came down to four candidates, IOM, March Audio, Audiophonics, and VTV. VTV is an unknown, but popped up when I was searching for hypex amps on Hifishark. It is from Vacuum Tube Values which gets cases made with their logo and then assembles various Ncore Models. I was originally looking at a NC122 but it was $489 while the NC252MP was $499. Same size case, $10 more, twice the power, it was a no brainer.
The VTV showed up last week and I had to let it break in as it was brittle out of the box. Just kidding. I received the VTV this morning. I didn't pull it apart, but the case is nice looking and it appears well assembled. I pulled out my Parasound and replaced it with the VTV. I did have to do a cable swap which put me back $75 as Benchmark was the only company that I could find that wires their RCA to XLR cables according to Hypex's recommendation.
The VTV sounds good to me. I did not do a bunch of back and forth swapping, but it seems to be a bit clearer and relaxed. I am guessing that when turned up the Parasound may have clipped a bit on peaks, while this does not. It is apparent if I turn the VTV way up (louder than I ever listen), it has the ability to overdrive the speakers.
All in all, I would rate the VTV as a great value for a Ncore amplifier. For those wondering, my desktop setup is a Dell Precision workstation running either Roon or Jriver, a Schiit Modi Multibit, Schiit Saga (thanks to their closeout for $200), VTV amp, Totem Mite speakers and a Rythmik L12 sub.
