• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Verum 1 : planar magnetic headphones
South Africa
Here are my brief impressions of the Verum One's after listening to them over a few days.
At first, they sounded quite underwhelming and thin. Powering them off of my phone and my PC motherboard resulted in a quiet, rather disappointing sound. But I burned them in over a few days and found a much better power source and these things came to life. After testing them on various high-end amps that I could find, I found that they scale very well!
The sound signature can be best described as dark, natural and dynamic. Bass is very flat and somewhat neutral, doesn't bleed at all through the midrange. Although it doesn't have the heavy slam and rumble some people have mentioned, the bass has some impact and is very well executed! Both upper-midrange and treble are recessed, but nicely detailed and the separation of instruments comes across very well. Soundstage is narrower than I expected, my Grado SR80e's come across wider, but the Verum's large drivers definitely create a "bigger" all-encompassing sound. I would still consider the soundstage relatively wide.
The build is incredible for a DIY headphone, it feels solidly built although a little cumbersome to handle, very comfortable to wear for long periods.
Overall I'm very impressed by what Garuspik was able to create, its such as pleasure to listen to these!
Note:
I have experienced a crinkling sound in the right earcup if I remove the headphone from my head (no effect on sound, so far).
Fluffy
I gave a listen to pair at a friend's house. They sound nice, but the build needs to be improved and that cumbersome headband needs to get more compact.
The main issue is the 8 ohm impedance, which means driving it with a high output impedance amp will give you a very bad damping factor. The amp he had there (SONY TA-ZH1ES) could barely handle them, and I needed to crank up the volume to get it to a listenable level. And it also sounded kind of muddy with that amp. Once I switched to my portable Fiio X3 v2 (output impedance lower than 0.1) they sounded much better.
Saying that low impedance headphones is easy to drive is a misleading generalization. 8 ohms means the amplifier has to output ridiculous amounts of wattage, and if the output impedance is high it means it actually resists outputting that power. This basically approaches speaker's territory, and according to common speaker wisdom, lower impedance actually means harder to drive.
I think a better design choice would be to go for a more manageable 16 ohm, if possible. Oh, and the front facing cable connectors looks like they might break with the gentlest hit.
I'm more and more thinking about getting one, as "upgrade" of HD650.
Also looking at used LCD-2.
Which one of the two would have the nicest bass ? It's something I think the HD650 misses a bit, so I don't really want to miss out on bass on my next headphones.
Icboschert
Wisconsin
Note:
I have the same problem on my unit. right earcup cuts in an out if it moved suddenly or snapped on to my head quickly. Sometimes this leads to some channel imbalance with left or right side being more dominant. I used to have heavy right side dominance until recently (smacked the cups around a few times on my head). If the imbalance remains I might send the unit in for repair but tough pill to swallow shipping from US to Ukraine. Don't even care about the money but the time spent without headphones would be a bummer.
Frank Dernie
Oxfordshire
I am using either my iPad or a RME ADI-2 Pro with mine they sound fine and loud enough for me with either.
Low impedance does mean more current but also less voltage, so the statement "ridiculous amounts of wattage" isn't true, though it is true some headphone outputs may struggle with high current (poor ones IMO).
Any headphone output with a high output impedance is a kludge IMO, either a series resistor to the main (speaker) amp or just not all that good.
pwjazz
Those of you who bought the Verum recently, did you get a tracking number fo r the shipment?
doctorjuggles
London, UK
Hi @Garuspik - will all headphones you ship from now on include the new restyle? (I have no idea when mine will ship, ordered them at the end of 2019, but if they ship with this new style that would be good news for me :)). Thanks for the update
G
Thread Starter #117
@doctorjuggles - thanks for you support! Your unit will be shipped this week and will have new grill, new better cable and 3.5mm sockets in cups (instead of previously used 2.5mm) but still old style headband. New headband exists only in one sample yet.
But all orders made after 25 January will receive units with new headbands.
But in a month or so I'll make new headbands available as user-installed options. It'll be very easy and inexpensive upgrade.
Veri
Good progress @Garuspik :)!!
Might not agree with your view on amp/DACs(haha) but that is one very attractive headphone, with great measuring FR. Congrats
G
Thread Starter #119
Thanks @Veri My main complaint about dac measurements on ASR - you don't measure shape of different waves (sinewave and rectangular waves) on low level signals. If you do so you'll see that r2r dacs that measure poor will have much closer to input signal shapes on output in comparison to chifi like topping.
maxxevv
So where do you get the "input" signal shapes as reference from in the first place ?
Similar threads
