Using cork in acoustic treatments
cata02
Anyone used cork when treating rooms?
Noticing official products in this regard, stating it can be used for acoustic treatments, but one specialist recenetly told me cork actually reflects sounds and it's a very bad material for treating room acoustics.
or
I had an idea of creating a bespoke acoustic panel based off of a 40mm recycled cotton or polyurethane foam and pur a layer of cork on the surface, for the looks and practicality of pinning pictures to it.
Thanks!
D
Deleted member 21219
Guest
The specialist with whom you spoke might be correct:
Good luck! :)
Jim
dualazmak
Just a joke post, please ignore this post.:D
I just assume/guess if you use 10,000 or more wine corks "randomly" and tightly placed on your wall (and ceiling?), it would effectively contribute to nice sound dispersion, lower the reflection and standing waves, I hope.;)
My major concern, however, is that you (and your family) could be completely wine alcoholic before completion of your wine cork wall.:facepalm:
fpitas
Northern Virginia, USA
Those products look "fluffed up", probably to make it a little absorptive instead of reflective.
alex-z
Cork is going to reflect most of the mid-range and treble, killing the effectiveness of your absorption material.
An ideal absorption panel has the lowest density material placed first, and the highest density placed last. That way you maximize both the operating bandwidth and low frequency efficiency.
C
cata02
I guess drinking so much wine would definitely solve the acoustic issues for good :D
RoarNSnore
It was enough of a problem for our family that we ended up buying a vineyard in Napa :). Can someone share links about why cork is a poor acoustic treatment source?
We are also considering covering a wall in cork for some sound absorption and aesthetics.
DWPress
MI
I built some QRD diffusers/absorbers for my rear wall soffit based on information that cork is good for acoustic treatment but I used chunky 3 inch cork that is very open in it's construction - the type used for insulating walk in freezers like this. They are faced with book board (high density card/chip board used for book binding) on the faces and wells while the sidewalls remain open for absorption.
I'm sorry I don't have the before/after measurements anymore, hard drive failure, but they made a significant difference in decay time from 80-250Hz.
There are all kinds of cork, the absorption coefficient chart shared above is for cork flooring which is more like linoleum and hard. Here's a link to a more extensive list of materials though cork isn't mentioned:
Fiberglass, Rockwool, Polyester, Cotton, and Sheep Absorption Coefficients
The center panel extends out into the room 8.5" and the panel is 7' 6" long.
kemmler3D
San Francisco
Good info. Although cork clearly isn't porous or light enough to do much to the treble, as others have noted in the thread, usually we have a lot more trouble in the frequency range you mentioned. It's not hard to find materials that are good at absorbing treble... 80-200hz is another story.
Midwest Blade
I put down a cork floor in my listening room and found it way to reflective, quickly purchased a deep pile carpet, problem solved. Cork flooring was easy to instal, provides a nice barrier to the concrete floor, the room is in a walk out basement so the concrete was treated for moisture barrier.
DWPress
MI
I'd say this stuff is on another level from cork flooring - very crumbly, porous and light.
