That's another pair of TTs that I might have liked to compare more systematically! But my SL1200 is long gone. As far as build quality goes, SL1200 Mk II is more impressive, with it's die-cast upper plinth, heavier platter, mineral-filled resin bottom cover, much higher torque, with near-instantaneous recovery time.
AT120USB (which I currently own) looks nearly identical at first glance. But is mostly made of injection molded (ABS? Polycarbonate?), including much of the tonearm, and much of the seemingly impressive heft is due to a couple of heavy steel plates, one or which is bolted to the bottom cover, and which seems to serve no purpose aside from adding mass. And yet, it works, and pitch accuracy and stability sound alright to my ears.
One area which is definitely substandard is the stock cable: Mine measured somewhere in excess of 200 pF. This is not a problem if you use the built-in phono preamplifier, but if using an MM cart into an outboard phono preamp, it's not ideal. [EDIT: On second thought as I review plot #3, eh, maybe not worth the bother of replacing the stock cable - it's thin and nicely flexible, and I save what, 80 pF by swapping with a thicker, stiffer cable?] Also, even when built-in preamp is supposedly bypassed, it's output remains in-circuit, and will produce confusing results if you try to measure cartridge loading via a capacitance meter.
All frequency response sweeps done using Analog Productions Ultimate Analog Test LP AAPT1 tracks 6 & 7, Ortofon 2M Red phono cartridge mounted on AT120USB turntable. Ignore discontinuity @ 1 kHz, as tracks 6 and 7 are recorded at different levels.
Using internal phono preamplifier:
Internal preamp bypassed via AT120USB's rear-panel switch, using phono stage of Douglas Self-designed Precision Preamplifier:
And finally, all traces of internal preamplifier taken out of circuit by cutting a couple of internal jumpers, using DS preamplifier as before:
Not sure as to cause of low-frequency droop in all plots, but subsonic filtering (which the DS-designed preamp definitely has) would be a Good Thing when dealing with vinyl playback.
Got something odd going on with middle plot showing high frequencies declining much sooner - the effect of part of the internal preamplifier remaining in-circuit?
Bottom plot looks pretty flat up to 10 kHz, but maybe could benefit from more, not less, capacitance? [sigh!]
I have not attempted to gauge crosstalk or immunity from overload, but internal preamp is quiet enough that noise from the record itself is all that I've noticed. Glad that I did not simply discard the internal preamplifier, as some tweakers have suggested, because at least as far as frequency response and noise are concerned, it looks more than alright.
