Hello,
I'v bought on Aliexpress BRZHiFi X30Y amplifier with TPA3255 inside. It works well but it heats quite much with or without input signal and with or without output load. After a couple of minutes looks through went holes termo cam shows over 60-70*C even on heatsink. It is not expected behavior of class-D, especially since my other class-D TPA3118 is cold like a fish.
Oscilloscope plugged on outputs shows sine wave of 450kHz (TPA default clock) and 3Vpp amplitude. Input signal modulates this "carrier". It is quite strange behavior. My TPA3118 has flat line without signal and clear signal with.
Could somebody confirm or deny, is it normal behavior of TPA3255?
What is the most possible cause? I would like to know before I will start digging inside.
Maybe somebody could measure by oscilloscope outputs own TPA3255 amp?
THX.
THX.
