Efficiency could just mean same performance in a smaller size.More VA per cm squared in a toroid, rather than efficiency per se.
Yah, I guess I have never seen a toroid with a gap. Again, no dog in this hunt, and far (far!) from my day job (though we use SMPS pretty much everywhere).A gap in a toroidal transformer or EI construction allows a bit of DC in the core without magnetizing it too much. If there is absolutely no DC present, lose the gap and go toroidal.
Thankfully I'm on the 230V side (not that I ever managed to stress it thought) .So how do you account the huge discrepancy between 220 and 110vac. Both voltages are well within the parameter of being able to supply the power at the outlet. This in itself leads me to wonder about the entire measurement process here. 220vac is always a superior outlet for power amplifiers, but this should not be a superior outlet until one reaches the max one would get out of a 110 outlet. Those measurements show a drop from 90 to 15 under a 110 outlet.
Looks to me like a good one to send to Williston audio labs, and have him put it on the amp dyno.
I've not seen a gapped toroidal, either. Maybe the single-ended tube amp people may have those, I dunno.Yah, I guess I have never seen a toroid with a gap. Again, no dog in this hunt, and far (far!) from my day job (though we use SMPS pretty much everywhere).
You might have forgot to add DC-DC operation.Obvious advantages of SMPs are small size, line/load regulation, universal voltage and AC/DC operation.
That is because the question does not make sense. Toroid is a type of transformer, SMPS is a type of AC to DC power supply. You can use a toroidal transformer in a SMPS PSU as well. I think what the OP means, is a mains frequency linear PSU or a high frequency SMPS better for a D-Class amplifier?I'm confused a bit. Toroids are used in both linear and PWM power supplies.
I should've said "operation from AC/DC" instead of "AC/DC operation"You might have forgot to add DC-DC operation.
Toroidal transformers are actually 95 to 99 percent efficient in performing power. Because most never differentiate between the the power supply and the amplifier module, most assume the transformer has a large degree of blame to be inefficient. It is the amplifier module that determines efficiency. When there is a marriage with the modified ab style amplifier module, and Class H. we see very high rates of efficiency in toroidal amplifiers.I thought lack of a gap made toroidal transformers less efficient than EI? Don't really care, curious. They are more sensitive to saturation from DC (etc.) without a gap. - Don
A transformer being a bottleneck? Now i heard just about everything!! But Yes, the biggest bottleneck is that its use is far too expensive compared to a grab bag of IGBT's. resistors and capacitors, and really puts a damper on PROFITS.Yes the DC problem with toroidal transformers are very real in rural areas. You can easily have DC components on your AC mains .
Btw this whole tread makes little sense ? It’s about implementation build your ps in whichever style you want it’s the result that counts .
I speculate that this is about making a feature out of problem unregulated power supplies with no regulation usually sags under load , like a typical linear power supply.
But it holds it’s voltage for a short while and has a bunch of stored energy in its caps , so you then measure ( market ) this as “dynamic power” “ burst power” , “power with a paperclip shorting the amp for a nanosecond”
And the temporary overload you can have on iron and copper components is quite large so a transformer supply can be abused over its spec in short periods.
If you use an SMPS just make it big enough to provide all voltage and amps the class-D amp board can handle and that’s it , you now have moved the bottleneck to the amp and power supply is no longer an issue.
That is true; toroidal transformers are more sensitive to DC current saturating the core than E-I types are. I have not seen a gapped toroidal transformer, though.I thought lack of a gap made toroidal transformers less efficient than EI? Don't really care, curious. They are more sensitive to saturation from DC (etc.) without a gap. - Don
I would be curious how DC current gets into a transformer, when it is plugged into an AC line. The conversion to DC is accomplished by the bridge rectifiers which are AFTER the transformer, of which the DC current is then smoothed by the capacitors.That is true; toroidal transformers are more sensitive to DC current saturating the core than E-I types are. I have not seen a gapped toroidal transformer, though.
Asymmetry of the positive and negative halves of the AC power sine wave that can result from asymmetrical loading of them can cause a net DC offset.I would be curious how DC current gets into a transformer, when it is plugged into an AC line. The conversion to DC is accomplished by the bridge rectifiers which are AFTER the transformer, of which the DC current is then smoothed by the capacitors.
Toroidal High power Class D amplifiers by Zepher in India.
I never see my favorite caps installed in SMPS power supplies, that being the 10000hr UCC KZN and KYB, that are designed with power supplies in mind, yet these capacitors run into being sold out all the time at mouser and digikey. I really wonder what products these are being installed in.
The 1000, 2000 or 5000 Hrs are design points for a given temp., ripple current, voltage and so on. If you stay below, you can reach dramatically higher live times. This is the real engineering task and has to be done in coincidence with the expected lifetime of the product. This datasheet values can only interpreted with the other parameters known.
